Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-11-2009, 11:11 PM   #1
byrd
Union Electrician
byrd's Avatar
??? about stall rpm
I have a crate 350 with 882 heads on it with a 350th and 3:73 rear. There is a guy locally that has a slightly used 2000-2200 stall for my tranny and I wanted to know if that was streetable or not, and what issues if any would arrise from the use of the stall. I do have a tranny cooler, not installed but will before I put the stall in. I do have plans for a posi rear as well, but would I need it before I put the stall in? TIA...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-11-2009, 11:45 PM   #2
dave38
Re: ??? about stall rpm
a 2200 convertor is very streetable. Sounds like its probably a 500 over stock stall convertor. I work at a tranny shop in meade county about 20 mins outside of louisville. I can get u a 500 over stock stall convertor for about $90 brand new. You probably wont need an extra cooler or anything unless you get up in the 2800 stall range. You wont have any driveability problems with a stall speed that low.
dave38 is offline   Reply With Quote
Old 01-12-2009, 08:11 AM   #3
djracer
djracer's Avatar
Welcome to the board Dave its great to have a tranny guy in the mix.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-12-2009, 02:55 PM   #4
meansting04
meansting04's Avatar
I would run a cooler and stock for a th350 is 12-1500. The 2200 is completly streetable, but with more stall comes more heat. Run the converter and the cooler. You will like the nice launch you get. BTW 882 are nice heads when they are worked over a bit.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 01-13-2009, 08:06 PM   #5
Tmiller
slims 68
Everything is streetable untill it pisses you off.
When you choose your converter you usually want to match it with your cam, or beter yet Torque #'s from a dyno. You want the stall to be just under the torque peak of the motor. This seems to work good for me.
68 c10 LWB, blown 454 , 550 hp & 600 tq est.
06 Chevy Cobalt SS supercharged 2.0L
08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it.
Tmiller is offline   Reply With Quote
Old 01-13-2009, 08:14 PM   #6
AlienYouth
AlienYouth's Avatar
i'm daily driving a 3000 stall no problem
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
