Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-13-2009, 11:54 PM   #1
70stroker
70stroker's Avatar
camshaft selection
need help asap.
im ordering my blower thursday and need help on a camshaft.
my motor is a 454 mostly stock bottom end. iron heads mildly ported. headers hei.. the trans a th350 with a 3200-3600 stall. rears a 4:11 with posi.
my question is what camshaft would be a good choice.
im kinda of thinkin i might go a little less converter and maybe 3:73s rather soon, to make it more highway friendly.
any and all help as fast as possibly is appreciated. thanks
70stroker is offline   Reply With Quote
Old 01-14-2009, 10:14 AM   #2
Ont67shortbox
Re: camshaft selection
I would call Cane,Comp,Lunati etc with all your specs and see what they recommend,they are in the business of grinding cams,you may require a custom ground cam for your application,
Ont67shortbox is offline   Reply With Quote
Old 01-14-2009, 02:59 PM   #3
Tmiller
slims 68
I'm running a Comp cam nitrous/blower cam 11-564-4. I like it. If you want to look elsewhere make sure you get a cam with at least 113 degrees of lobe seperation which keeps from bleeding the boost out the exhaust and you want a split duration, more exhaust duration to help scavange the cylinders better.
68 c10 LWB, blown 454 , 550 hp & 600 tq est.
06 Chevy Cobalt SS supercharged 2.0L
08 Chevy silverado crew cab 1/2 ton 2wd 5.3L, she wont let me put a supercharger on it.
Tmiller is offline   Reply With Quote
Old 01-14-2009, 07:04 PM   #4
Tmiller
slims 68
Take a look at the engine analyzer post by super 73, page 4. He punched in my #'s with the stock 6"crank pulley and with the overdrive 7" pulley.This will give you an idea of the hp my set up is getting and yours is pretty much identical to mine.
You might want to see how that converter feels, I'm running a 2500 and 3.73 gears and it leaves strong. That 3200 may be a bit high, you'll find that with the added torque of the blower will make that coverter flash a bit higher.
Old 01-14-2009, 09:24 PM   #5
70stroker
70stroker's Avatar
are you happy with that cam?
Old 01-15-2009, 04:50 PM   #6
Tmiller
slims 68
I am, for building the engine with a 6k rpm limit and planning the build on more street usuability it seems like a good choice to me. It has lots of grunt down low and pulls like hell to redline and smooth all the way through, smooth idle at 800 rpm.
I think going any larger would put my peak HP past my 6k rpm limit.
Old 01-15-2009, 05:01 PM   #7
Tmiller
slims 68
The only thing I'd possibly change is maybe having the same grind made in a hyd. roller, with maybe a bit more lift to use the flow #'s in my heads a bit more.
Old 01-15-2009, 10:56 PM   #8
custom72c20
custom72c20's Avatar
I was going to recommend something that I have, but you said you were looking to make it more of a cruiser. My specs are around .690 lift with around 310 duration (sorry I can't find my cam card and its a custom grind). My power band is around 3 to 7 grand but I don't spin it that hard due to mainly stock internals. I would look for something in the .550 to .575 lift with about 285 duration. It would still be a stout cam but with a lower power band and more low end torque IMO.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
