Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-16-2009, 01:58 AM   #1
70stroker
70stroker's Avatar
lsx carb swap
Alright guys so i have been thinking about doing a lsx swap to my 79 trans am. My question to any and all out there, is if i get a lsx motor and choose to carb it, do i need to worry about the computer that originally controlled the motor and all its sensors? Also is it possible to bolt up to a th350 or 400th?
Ideally im tryin to get it done without have computer contolled items on the motor trans.......
just tossing up the idea...
70stroker is offline   Reply With Quote
Old 01-16-2009, 08:59 AM   #2
djracer
djracer's Avatar
Re: lsx carb swap
It can be done but I would keep the injection.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-16-2009, 10:47 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: lsx carb swap
All you'd need to run a carb is an ignition module (MSD makes one) to fire the stock coils. The only sensors you keep are the crank and cam position sensors. A th350 or 400 will bolt up with a dedicated flexplate.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-18-2009, 06:49 PM   #4
Super73
Super73's Avatar
Re: lsx carb swap
You could spend big money as well and put a belt drive distributor on it. Personally, I would keep the injection and individual coils, retaining the factory computer. With injection/timing controls it gives you the ability to adjust timing and fuel in 400rpm increments. You can dial it in extreamly well and it is super easy..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
