Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-18-2009, 12:31 AM   #1
t&tkennels
t&tkennels's Avatar
need help with heads
My '71 has a 350 2bl. from a 78-80 model passenger car. it has 1970126 heads & from what i understand they low performance , 76cc,1.72 int. valve heads. i think the stock compression is 8.0 or 8.5 . what i want to do is raise my compreesion up to 9.5-10.0. i found a set of heads for $400.00 with 65cc chambers & 2.02 & 1.60 valves with a 3 angle valve job. will these heads give me the compression i want.?other specs of the engine will be as follows, performer intake, 600 edelbrock, 279 comp cam thumpr, 1&5/8 headers & 2 and 1/2 exhuast. Thanks
t&tkennels is offline   Reply With Quote
Old 01-18-2009, 12:38 AM   #2
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: need help with heads
Sounds like the right path. I have 64 cc Trick Flow 2.02. 10:1 compression. 290 duration Crane cams fireballII. Weind stealth intake, with a holley 650 going out 2.5.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 01-18-2009, 12:40 AM   #3
westbrookw
westbrookw's Avatar
The heads won't give you the compression. You need to swap your pistons out.
72 SWB/Step
Old 01-18-2009, 02:05 AM   #4
custom72c20
custom72c20's Avatar
I think a .100 dome piston would put you in that compression range with those heads. You can cut the heads down a little to gain a better gasket mating surface while raising the compression slightly.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 01-18-2009, 01:08 PM   #5
t&tkennels
t&tkennels's Avatar
ok i went to comp cams web site, & they recomend 9.0:1 compression for this cam. will the heads at least give me that.? i really dont want to go into the bottem end of the engine ,cuz for one its in exellent shape & i really dont have the money to do so. but i really need to replace the heads cuz i know i cant make any power with the stockers, Thanks for any & all help.
Old 01-18-2009, 05:39 PM   #6
t&tkennels
t&tkennels's Avatar
Somebody?
Old 01-18-2009, 06:24 PM   #7
djracer
djracer's Avatar
that should get you close. You might want to look at a good used set of vortec heads. the standard 350 versions have 64ccs but you would need a vortec intake. I think the 305 versions have smaller chambers.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-18-2009, 06:45 PM   #8
Super73
Super73's Avatar
Patriot was doing a special on their Vortec heads. They are a Patriot casting which allows you to run both a standard intake or Vortec as well as either perimiter or center bolt valve covers. For the money, they are a great head IMO..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-18-2009, 07:54 PM   #9
custom72c20
I agree X2.
Nick
