Old 05-14-2002, 09:17 AM   #1
CARS4567
Post OPTION QUESTIONS??
FROM GLOVE BOX SHEET:
1971 3/4 2wd...
1) G86-NO SPIN REAR AXLE
2) M20-4spd TRANS
DOES THAT MEAN JUST A LIMITED-SLIP AND A REGULAR GRANNY LOW 4spd?
CARS4567 is offline   Reply With Quote
Old 05-14-2002, 09:37 AM   #2
jku72
Post
A no spin is not a limited slip, but is similar in a broad sense. A no spin allows no spin, whereas a limited slip allows some slip.
The tranny is a granny.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-14-2002, 10:53 AM   #3
ckhd
ckhd's Avatar
Post
G86 No-Spin is basically a detroit locker. Hard to explain, but the slower wheel gets the power, i.e., in a turn, the inside wheel drives the pickup, and the outside coasts, but if the inside slipped (ice or something), then the locker would put power to the outside. The way I understand detroit lockers in my head is like you have two ratchets hooked to the axles. The ratchets spin at the same time, but you could spin the axle faster than the ratchet (as the outside wheel in a turn would do), and it would click the gears in the ratchet and spin faster. The inside wheel wouldn't be spinning faster than the ratchet, so the ratchet would drive it.
Probably doesn't make sense, but it works for me.
The M20 transmission is the CH465 Chevy 4-speed with granny low (I'm pretty sure).
Bowen
'68 K20 fleet
'69 K10 swb fleet
'72 C10 lwb step
'72 K10 Suburban
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 05-14-2002, 12:06 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
M20 is SM420 if the truck is a 67 or older, otherwise is the Ch465.
Fast68Chevy is offline   Reply With Quote
