![]() Join Date: Jul 2006
What else do I need?
I've got 4 bags, eight 3/8" SMC valves, tank, compressor, fittings, and switchbox coming for the 72. Other than line, mounting brackets for front, and c-notch, what else do I need? Drop spindles? New Panhard Bar? I saw something about a shock relocator kit, will I need this?
#2 | |
Re: What else do I need?
4Ga For the compresor, Really?
What about the shock relocator kit?
sorry. i meant 8ga.
67-72 parts collector,…
![]() Join Date: Nov 2002
Yes,... shock relocators shorter shocks front and rear, and an adjustable track bar (panhard bar)
I suggest looking at Early Classic Enterprises (ECE) for all of the above items.
A guy with a truck
You're gonna want blocks too. Get your shocks at PepBoys and save some cash. Do the cheap blue Monroes- same thing ART uses without the cool sticker and inflated pricing...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
A guy with a truck
You will want the 2" lowering blocks. This will give you a good ride height while still allowing for some decent pressure in the bags= better ride quality. It will also bury you in the notch when aired-out.
Shocks: Front- Monroe 33033 Rear- Monroe 32301 The rear shock selection assumes you are using shock relocators and 2" blocks. Deviating from this recipe may cause the shocks to bottom out. Don't pay more than $20 each for them or you're getting ripped off...
VA72C10
![]() Join Date: Mar 2008
Most people use 2" drop blocks....there are several board members including ECE that sell them...just make sure you get the longer U-bolts with them. They basically allow you to ride with more air in the bags for a better ride.
Thanks for the part #s on the shocks I was lookign for those...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 02-03-2009 at 05:24 PM. |
ya need to start bolting stuff on, ha ha, just kiddin, good luck on the total install.
#13 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#14 |
If that's correct they are too long.
#15 |
BUMP. This would be good to know
#16 |
A guy with a truck
The 33033s are listed as stock replacements as well, but they are definitely short enough. I dunno?
We just installed the 32301s on a buddy's '65 C10 with RE7s, relocators, and 2" blocks. Worked perfectly. I have a set on the shelf awaiting install on my '70 C10, similarly equipped. My measurements say they will work. There should be just over 12" between the relocator's mounting eyes out back when aired-out. The 32301s are 11.875" compressed. Best bet is to measure for your individual needs. Very rarely do I trust the internet without verifying for myself- been burned a few times on that deal- trucks and individual results may vary...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-04-2009 at 06:45 PM. |
#17 |
Here's a good list of front and rear shocks off of CPP's website.
#18 |
VA72C10
Thanks for the info!
#19 |
The KYB's that ECE sells for their 6" rear drop are part # 344067. I saved the end off of the box.
Does anyone have the actual part number for the dropped KYB's that ECE uses up front? CPP lists them as #KYM1200G off of the above list I posted. I need the real part number.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-05-2009 at 08:36 PM. |
#20 |
good info here...
#21 |
Tot Roddin'
Bump for a possible answer...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
