Old 02-05-2009, 06:37 PM   #1
6772king
6772king's Avatar
rear air switch??
hey guys,, I just bought a 72 sub for parts just so i have them one if I ever get one,,, my question is on the rear air the switch is there but someone removed the knob,, were they the same as the headlight and wiper knobs??? there also looks like there is a stud missing that goes into the swich?? thanks in advance.
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 02-09-2009, 06:39 PM   #2
grebus1
grebus1's Avatar
Re: rear air switch??
There should be a short stalk coming out of the switch assembly. I believe the knob is the same as the ones that are used on the factory radio (it just slips on over the stalk), but you might be able to use a wiper switch knob too. The headlight switch knob has a stalk built into it, so it's different.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 02-09-2009, 08:42 PM   #3
jorgensensc
jorgensensc's Avatar
On my '72 it is the same as the wiper knob wit the flat side and the set screw.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-13-2009, 11:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
my 72 is the same as the wiper knob too, but with the shaft missing from the switch it's not gonna work.
