Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-05-2009, 08:41 PM   #1
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Back half advice
I am needing to back half my truck. The previous owner has already cut off the frame.
The frame has been boxed from the cab forward. I am planning to use the trailing arms and I am thinking of just adding 2X4 from where it is cut to the back. What would I need to use for bracing?
It may be a season or two before I "need" a cage, but I want this truck to be pretty stiff and go straight.
What are your suggestions?
Here is some pics of what has been done.
I plan on using coil overs on the rear.
Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 02-05-2009, 10:32 PM   #2
rookierodbuilder
rookierodbuilder's Avatar
Re: Back half advice
I do not know much about chassis work, but if that were my truck, I too would keep the trailing arms, I would put the frame rails closer together for wider meats and set it up with an adjustable anti-sway bar and some adjustable coil-overs. A quick and dirty way of doing that would be to order the back halve kit for a four link from a race parts supplier and modify it for that purpose.
rookierodbuilder is offline   Reply With Quote
Old 02-05-2009, 11:18 PM   #3
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Dude that chassis looks sweet! is that diamond plate for your frame boxing?
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-06-2009, 01:04 AM   #4
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Thanks, Diamond plate it is. All of this was by the PO that got bored and went on to another project. At least most all of what he did was nice and we got a good deal on it too.
Old 02-08-2009, 03:15 PM   #5
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
The back half will need to "kick up" 10-11" to get the rear to match the fronts height. .
I'm wanting to use 2X4 rect tubing. just angle it up, then run it back to the back of the bed. I will need at least a cross brace for the coil overs.
Would running 2X4 for the coil overs be good? Too much, not enough?
What other bracing would help to make it strong and reduce flex/twisting, without adding unnecessary weight?
It doesn't seem like much is used when you back half a car and with the trailing arms cross member mounted in the original frame area, I'm not sure what else is necessary.
Old 02-09-2009, 02:08 PM   #6
djracer
djracer's Avatar
I would just use 2x3 here's how mine looks.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-09-2009, 10:47 PM   #7
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Kevin, I often check back on yours to check out what works. Thanks for the great build thread and pics.
I may not go with a cage for a while. Wondering how that would affect my frame and any twist.
Most drag cars I have been around that have been back halved also have cages.
I may have to bite the bullet and cage it, but wanted to get going soon with a NA engine and work into things.........
Old 02-09-2009, 10:58 PM   #8
djracer
djracer's Avatar
the cage strengthens the chassis but I think the rear frame would be fine without a cage for awhile.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-09-2009, 11:52 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
I agree with the 2x3 square . Looks like the trailing arms are just tacked in the truck to move it . I would build the kick up with upper shock mount , buy or build ( i would buy ) a set of ladders , fab a front mount cross member and hang a 9" under it . No offense to the trailing arm guys in the group , but your this far just finish the rear and go racing .
At this point the tire choice needs to be made . I would pick a tire and rim combo with a common ofset or back space and build the backhalf for it . This may not be the correct way , but it is the only way i know . I built mine to factory specs and wish i had done some research first . I would have narrowed the rear axle to take 5.5" back space that way i would have the same wheel most mustang and camaros use . You'll probably run a bigger tire than me . There are alot of true 10.5 race cars down here so 29.5 x 10.5 x 15's can be had with 8-10 passes on them for $100-$150 a set . A guy could set his rig up for a popular tire like that and and get tires on a budget . just a thought . Raland
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-10-2009, 07:07 PM   #10
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
The tack on the trailing arms is just to be able to move it. No where to put the springs or coil overs. But the front is mounted securely to a custom crossmember.
29.6X10.5 Seems like a good size tire for me, even tho I am full size. Is there a commonly used size that you think would work better. I like the idea of using cheap available barely used slicks. But i have no idea what is commonly used.
I will need to be over tired for a while....until I can get the horsepower up a bit more. I would rather be a bit big rather than too small.
I have a 9" available and a fair selection of gear sets. So i can work ratio out after i select a tire.
Thanks for all the help.
Old 02-10-2009, 09:27 PM   #11
djracer
djracer's Avatar
I run take off 33x10.5w tires. They are cheap.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-10-2009, 09:31 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
I don't know if There is a big outlaw class in Dallas , but you could always look at a 10.50 W . It is like 11.7 " wide and they can be stiff sidewall or regular . They also can be up to 33" tall . Any "bracket/sportsman" race size tire is going to be used until it's dead . Alot of the grudge race guys use these take offs .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-11-2009, 12:26 AM   #13
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Looks like 10.5 wide are popular.
Would you think that laying out the back half to have room for a 11.75-12 inch wide (sidewall) with 5.5 b/s wheel would give me the best chance for finding good cheap used slicks.
Also, Would a 10" wheel be the correct width for the 10.5 wide slick?
Lee
Old 02-11-2009, 08:24 AM   #14
djracer
djracer's Avatar
I run a 10 inch wheel but I want some 12's! A twelve is a better fit for the w tires!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-11-2009, 12:22 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
Lee
Yea , i'd lay it out for a 33x13 and run a 10.5W . That way it would just be a tire change not a rebuild . The W's come in 29.5 , 31 & 33 . The true 10.5 are popular in 28 & 29.5 . Giys down here are running below the 4.teens on W's and like 4.66 on true 10.5's .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-12-2009, 12:07 AM   #16
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Don't think I will be able to start on this before I leave for another job (and be gone for a WHILE). But this lets me start gathering parts. I will go of the 12" wheels and allow for "up to" a 13 wide slicks.
I have more questions and will start a new thread for those.
Lee
