05-13-2002, 05:12 PM | #1 |
LockRite, TrueLocker, Detroit, Auburn - What works best?
I'm trying to figure out this rearend thing. I've surfed the net and find nothing but conflict on which works best. I have a Dana-60 OPEN, 30 spline in my 71' C20. I take it to the drag strip only to compete with myself to see if I can make it run better each time. "TRACTION" is a major problem and two tires grabbing are better than one. I'm trying to find out what can be done to my rearend to make both tires bite and not bang and clang when I drive on the street. One article says this brand will work and then another says it won't. Most articles talk about great traction off road not pavement. What have you guys done?
05-13-2002, 05:42 PM | #2 |
now thats a true COON DOG
I always thought that the stock posi unit was a good choice. I have one in my 1/2 ton burb and can't get the tires to spin, even when holding the brakes..... I think is an Eaton. Correct me if I'm wrong anyone.
------------------ 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi
current project 67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!) 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well... 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
05-13-2002, 09:00 PM | #3 |
Collector of rusty Items
Eaton has a new electric locker that you can turn off for a nice ride and turn on when you need it. A locker can be a real danger on snow and ice, so it is nice to be able to turn it off.
This is the one I want. http://www.rockcrawler.com/techrepor...view/index.asp http://www.torquecontrol.eaton.com/prod1.htm ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
05-13-2002, 09:11 PM | #4 |
Put in a spool for strip only.
Use a positraction (1/2 ton) or PowrLok (Dana 60). If you're not beating on it and have tires smaller than about 33", a Lockrite in your open carrier is a cheap and fairly good option, and did I already mention its cheap? ------------------ Just as if I knew what I was doin'
Just as if I knew what I was doin' |
05-13-2002, 09:14 PM | #5 |
Oh yeah,
Did I mention, that Eaton ISN"T CHEAP Like 800 bucks Duallie has a good point! ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. [This message has been edited by Scrub (edited May 13, 2002).]
05-13-2002, 11:03 PM | #6 |
Slowly getting CRSS...
got an auburn posi in mine, pops like crazy driving in parking lots, but its only got 1000 miles on it. and i like to now its back there.
------------------ Lutz, Fl My Team Website The Heavy Chevy Website ------------------
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
05-13-2002, 11:07 PM | #7 |
I have a detriot locker. I have around 3000 miles on it now since November. I love it. It pops every once in a while when I either pull away from curbs or turn corners, but not usually. Best for LWB trucks.
Here's where I got it: Randy's Ring & Pinion ------------------ '69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed! '69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast). Seattle, WA. *See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
05-14-2002, 02:14 AM | #8 |
Duallie,
Do you have a link to Lockrite. Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
05-14-2002, 02:35 PM | #9 |
If you want a lockrite locker, I think I have the piece of crap I blew up somewhere that you can have. If you are taking your truck to the drags or smoking the tires then you will just blow it up like I did. There are a few people on this board that have them and like them. There are a few that have bought them, blew them up and had to buy a real posi unit. I would highly recommend spending the money on an Eaton or an Auburn the first time. Ask some people who didn't listen and spent $300 to $400 just to blow it up. They aren’t worth the heartache. In my opinion that company has made a very unsafe product that will eventually cause some people to die in an accident. Mine almost did!
------------------ Supercharged 388 stroker in a 70 GMC Short box stepside 72 K/5 Blazer
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
05-14-2002, 03:09 PM | #10 |
Led Sled! Discs R 4 ME!
With a street driven truck that only sees light strip time I would suggest a limited slip carrier (posi). These are quiet on the street, easy on the driveline and work well.
Let us know what your set up and numbers are and how the limited slip helps. Denny ------------------ Toms River NJ (Transplanted Hoosier) 56 working Street Rod(under construction 71-2 coil chassis) Give a man a fish and he will eat for a day. Teach him how to fish and he will sit in a boat & drink beer all day. |
