Commander Taco Bello
boxing a frame
so I'm getting ready to start on my '50 project, and am doing some planning. I plan to box at least the front half of the frame, but am not sure what thickness of steel to use. I have a lot of clean 3/16 steel laying around (15 sheets, 30" x 16") that i could use, but that seems to thick.
Should i go get some 1/8"? |
Argon User
Re: boxing a frame
I would use 1/8, Easier to cut and form....
Re: boxing a frame
if you already have 3/16s IMO dont go buy 1/8.
off topic but do you hit any minnesota shows
1981 - C-10 SCSB Planning on putting this thing on it's rocker! ![]() |
Re: boxing a frame
Bodydropped71
Re: boxing a frame
Its really up to you. I did all mine with 3/16 i think. All i had then was a cut-off wheel. Now that i have a plasma cutter everything would have been 100x easier.
Re: boxing a frame
yeah, that's my situation too. I'm gonna need to buy stock in cut off wheels if i go the 3/16 route.
I haven't made it to any MN shows, but i'm not opposed to it. Got any good ones up that way? |
![]() Join Date: Dec 2007
Re: boxing a frame
What is boxing a frame, and what purpose does this serve?
Happy to be here
![]() Join Date: Mar 2000
Re: boxing a frame
Most frame rails are C (three sided) channels. Boxing a frame is accomplished by making a filler panel for the fourth side. This makes the frame more rigid, and cleans up the appearance.
It'd be alot cooler if you did
Re: boxing a frame
I would not use 3/16. I used 1/8 on the small section where I boxed mine. Not that expensive... Just consider all the extra weight.
![]() Join Date: Aug 2006
Re: boxing a frame
As others said. 1/8" is plenty strong and even though you have the 3/16" I still wouldn't use it. Save that for incase you have to make any brackets for the truck and buy some flat stock. Good luck and let us know how it comes out!!!!!!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: boxing a frame
See if you can barter, trade the 3/16" for 1/8". You are only planning to do the front half for now anyway.
Plus the extra labor should you ever need to drill or cut through it for elec., plumbing. I would look for 1/8" See as a matter of fact if you where close you could do my truck too, help of set the cost you were trying to avoid... |
Re: boxing a frame
I boxed the frame on my 54. It certainly stiffens the ride. Suggest you identify all the through frame connection points for rear cab mounts, bed mounting, rear bumper mounting, etc so you can identify where you need to have access holes.
It goes without saying though to use short welds to keep heat build-up down. Excessive heat will warp the frame. |
