Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-21-2009, 08:19 PM   #1
custom72c20
custom72c20's Avatar
BBC Horsepower Estimate
I am currently building a big block and was wondering if I could get some input on how much power it will make. Here is a list of specs:
468ci
-10:1 compression
-stock crank and rods
-1969 427 vette heads (ovals) 3919840 casting numbers
-- 2.19 int. & 1.88 exh. valves with some port work and bowl blending
-hydraulic cam with .575/.575 lift and 306 total duration on a 108 lobe center
-RPM Performer Air Gap Intake-Edelbrock (dual plane)
-Holley 800cfm double pumper
I'm thinking in the 500 range, but you never know. All help is appreciated. Thanks.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 03-22-2009, 12:24 AM   #2
1BAD70CHV406
Re: BBC Horsepower Estimate
Ya you sound like you are in the 500 range but what heads do you have. with a desent set of heads you should be making well over 500 close to 550 and of course it will be a torque monster bc of the big CI
1BAD70CHV406 is offline   Reply With Quote
Old 03-22-2009, 03:58 PM   #3
custom72c20
The heads I have are similar to the 781 heads. Thanks for the input.
Nick
Old 03-23-2009, 12:16 AM   #4
Rodms
Rodms's Avatar
Maybe high 4 s
Built chevy tuff!
Rodms is offline   Reply With Quote
