Old 05-15-2002, 12:12 AM   #1
71GMC 4x4
Post Difference between 3 series and 4 series carriers?
I have a posi carrier for a 12 bolt. I need to know what series it is. How can I tell the difference between a 3 series and 4 series? I'm going to 4.56 gears, and I don't know if I need to buy thick gears or regular gears. Please help me out. Thanks, Albie
[IMG]http://mustangmods.com/publish/topless99/truck2.jpg[IMG]
71GMC 4x4 is offline   Reply With Quote
Old 05-15-2002, 12:18 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Post
What was the gear ratio originally installed on the carrier. A 3 series carrier is for up through 3.73. A 4 is for higher than 3.73. The difference is the thickness of the ring gear mounting surface.
I believe that you can use taller gears (ex. 3.07) on a 4 series carrier if you use a shim, but you can't go back the other way?
Am I correct?
-Jeff
"You might be a REDNECK if someone yells 'Hoedown' and your girlfriend hits the floor"
-Jeff Foxworthy
'69 C-10 LWB (hot rod)
'67 C-10 SWB (hot rod in progress)
'92 K1500 'Burban (daily driver/tow vehicle)
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-15-2002, 12:42 AM   #3
texnician01
texnician01's Avatar
Post
yes you are correct. the 3 series carrier is for 3.07 to 3.5? gears.(they only used 3.07's 3.73's and 4.11's in our trucks) the 4 series carrier is for 3.73 and up gears. here's the way to tell the difference. just take these measurements.
doesn't matter if they are open or posi.
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
[This message has been edited by texnician01 (edited May 15, 2002).]
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 05-15-2002, 06:59 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Tex,
Excellent post!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-15-2002, 12:43 PM   #5
71GMC 4x4
Post
Cool, Thanks Guys!!
Old 05-15-2002, 01:05 PM   #6
bigvinnie
bigvinnie's Avatar
Post
tex, looks like the 3.07 is open and the 3.73 is posi..?? I have an open 3.73 carrier that has a much smaller flange depth, like less than 1/2 inch, but has the tapered casting that you point out in your pic...
I assume the difference between mine and yours is based on whether it's posi or open...??
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-15-2002, 06:23 PM   #7
texnician01
Post
yes one of these is an open carrier while the other is a posi. The place that you measure to is the face where the ring gear touches. these all have to be the same within the same series, open or posi.
I also noticed that some of the castings are a little different. I was unsure of what you were asking but I hope this helps. thanks
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 05-15-2002, 08:13 PM   #8
bigvinnie
bigvinnie's Avatar
Post
tex, where you show a measurement of 1 7/8 inches on the 3.73 carrier, my 3.73 open carrier measures less than 1/2 inch.... but my casting tapers toward the roller bearing just like the one you have pictured...
I'm thinking that some of your flange depth could actually be part of the ring gear casting, like 71GMC is talking about, thick vs. regular gears....??
72 Stepside Project
Old 05-16-2002, 11:29 AM   #9
texnician01
Post
bigvinnie you are measuring from the table top to the bottom of the ring gear correct? dont' measure the flange width that pic is kind of missleading. just measure from tabletop to ring gear mounting surface. the thick and regular gears he's talking about is to adapt gears between carriers. you can only do this on a series 3 carrier though. if you want to put 3.73 gears on a series 3 carrier you have to have a thicker gear because of the flange offset. you CANNOT put 3.07 gears on a series 4 carrier though. they would have to be paper thin in order to fit.
I'm still not catching on to the 1/2 inch thing though.
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 05-16-2002, 11:44 AM   #10
bigvinnie
bigvinnie's Avatar
Post
tex, you are correct, the pic is very misleading.... the red lines suggest that the 1 7/8 measurement is for flange thickness only, not from table top to bottom of ring gear... that clears things up, thanks.
72 Stepside Project
Old 05-16-2002, 11:58 AM   #11
texnician01
Post
ok, I get it now. sorry I was a little slow on the uptake myself. the pic was done a while back for another guy and I drew the flange lines in cause I didn't want him to think that the step on the 3.73 carrier was a spacer plate. this one should help a little.
sorry, my lightbulb just took awhile to warm up and turn on...LOL!!
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 05-16-2002, 12:07 PM   #12
bigvinnie
bigvinnie's Avatar
Post
yeah no problem, if I'd looked at the ruler instead of your lines I would have seen what you were talking about... learned something about carriers so it's all good...
72 Stepside Project
