Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-05-2009, 05:30 PM   #1
72 SUPER10
72super pics test
<a href="http://s648.photobucket.com/albums/uu202/72super10/?action=view&current=Picture005.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu202/72super10/Picture005.jpg" border="0" alt="Photobucket"></a>
72 SUPER10 is offline   Reply With Quote
Old 04-05-2009, 05:35 PM   #2
Alex1
Alex1's Avatar
Re: 72super pics test
Nope.
Alex1 is offline   Reply With Quote
Old 04-05-2009, 06:15 PM   #3
mongoose
mongoose's Avatar
copy the bottom most link that pops up in photobucket and past it to the paste... the [img] one.. and you get this.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-05-2009, 06:50 PM   #4
72 SUPER10
dang it i cant seem to make it work ,i got some more , my comp wont let it happen, thanks for posting this one at least. my photobucket is http;photobucket/72super10 if you guys are intrested in help[ing a dummy .thanks vince
Old 04-05-2009, 09:03 PM   #5
CoggedBelt75
CoggedBelt75's Avatar
Here are the rest
CoggedBelt75 is offline   Reply With Quote
Old 04-05-2009, 09:34 PM   #6
dragula
I could've swore that was me trying to post those !! LOL !!
dragula is offline   Reply With Quote
Old 04-05-2009, 10:00 PM   #7
72 SUPER10
thanks for all the help, hope you like the truck, thanks vince
Old 04-05-2009, 10:57 PM   #8
nxtruck
nxtruck's Avatar
VERY nice looking truck Vince!!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 04-06-2009, 12:14 AM   #9
tubbed 68
what brand wheels are the fronts and what size and bolt pattern are they.
tubbed 68 is offline   Reply With Quote
Old 04-06-2009, 12:33 AM   #10
72 SUPER10
the wheels are 15x3.5s and are 4-3/4 bolt circle,brand is weld aluma stars 2.0
Old 04-06-2009, 12:39 AM   #11
72 SUPER10
thanks chris, im installing the big block from my old car now , and will be installing the cage as soon as the weight and ride height is done. vince
Old 04-06-2009, 07:19 AM   #12
djracer
djracer's Avatar
What did you do to swap the front lug pattern?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-06-2009, 10:02 AM   #13
72 SUPER10
A local shop ,its a spindle,strange brake rotor, caliper, ball joint,tie rod, brake line, kit all bolt on for 1375.00 + shipping
Old 04-06-2009, 04:31 PM   #14
pro street 70
pro street 70's Avatar
djracer what i did to my 70 was get a set of new truck rotors cut off the studs weld and grind smooth .then my buddys shop used a old car wheel to drill new holes at 4.3/4 between old studs.cost me 100.00 + six pack.
1970 chevy short step blown 355
pro street 70 is offline   Reply With Quote
Old 04-06-2009, 05:44 PM   #15
72 SUPER10
Yes, that is what i had, it will work i took off a lot of weight with the new set up,it has slotted hat style disk and alum rotor with 4 piston alum calipers.
Old 04-06-2009, 05:48 PM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Beautiful truck Vince!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-06-2009, 06:08 PM   #17
72 SUPER10
Thanks much
Old 04-06-2009, 09:57 PM   #18
tubbed 68
wut size front and rear tires
Old 04-06-2009, 11:57 PM   #19
72 SUPER10
front is a moroso ds5 28x4.5 rear is phoenix 29.5x10.5
Old 04-07-2009, 08:14 PM   #20
JAKA
Cool truck!I have a few questions if you don't mind. First is Do you have any part numbers for the front end parts from Strange?Second is Has the rearend been narrowed any?And third is Do you have any pics of the frame and suspension?Thanks.
JAKA is offline   Reply With Quote
Old 04-07-2009, 09:21 PM   #21
72 SUPER10
THE ROTORS AND CALIPERS ARE FOR A 1990 CAMARO ,THE SPINDLE IS FROM BELL TECH 1985 CHEVY LIGHT DUTY 1/2 TON TRUCK,THE UPPER BALL JOINT IS A 72 TRUCK , AND THE LOWER IS FOR THE 1985 TRUCK,BRAKE LINES ARE 18 INCH FROM EARLS , YES I NARROWED THE STOCK 12 BOLT 2 INCHES ON EACH SIDE,THE ONLY REASON I NARROWED THE REAR IS BECAUSE I WANTED THE DEEPER LOOK RATHER THAN THE SHALLOW OFFSET REAR WHEEL, AND INSTALLED THE 33 SPLINE STRANGE PRO RACE AXLES AND FULL PRO RACE SPOOL. IT HAS FACTORY STYLE SUSP IN THE REAR WITH C NOTCH AND STOCK FRAME RAILS, LOWERING SPRINGS,SHOCK RELOCATERS AND TRACK BAR, I WILL BE GLADE TO HELP ANY WAY I CAN, I HAVE SOME MORE PICS BUT IM HAVINGPOSTING, THANKS VINCE.
Old 04-07-2009, 09:29 PM   #22
69trk
69trk's Avatar
very nice!!!!!!!!!!!!!!!!!!!!!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-08-2009, 07:50 AM   #23
djracer
djracer's Avatar
call me if you need to and I can probably help with posting pics. I'll pm you my cell number
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-09-2009, 01:36 PM   #24
regan wilson
regan wilson's Avatar
Very nice truck ! I like the wheels too !
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-09-2009, 06:25 PM   #25
Marv D
Registered Truck Offender
Marv D's Avatar
That is SWEET. Nice job!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
