Old 05-16-2002, 11:28 AM   #1
Woodinc
Post Need recommendations for 71 C10
I just purchased a 71 C10 350/350. I need to replace the water pump and starter and have already replaced the battery. I'm going to change the thermostat and oil at the same time. The air filter looks new but I think I will replace it also. While doing the water pump I'm going to look at the timing cover to see if it is leaking and repair if necessary. Do you guys have any suggestions as to anything else I should look at while I have the front of the motor off?
Thanks,
Todd
Woodinc is offline   Reply With Quote
Old 05-16-2002, 11:40 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Post
You have to drop the front of the pan an inch or so to replace the seals on the timing cover. It is a pain.
The original 350 came with plastic tooth timing chain sprockets. I has lost at least one in a real bad place to try and fix it. If I was going to take the timing cover off, I would at least look really hard at the timming chain and maybe replace it with a real-steel-deal.
Belts and alternator?
Might think about having the radiator rodded out. They seem to like that about every 5 years, but it isn't so cheap.
Fuel pumps seem to last forever. My truck has a fuel filter that is right near the fuel pump. It would be easy to change with the front off.
Good luck
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 05-16-2002, 12:03 PM   #3
Randy70C-10
Randy70C-10's Avatar
Post
Scrub's talking about the oil pan. Since you have to drop it, you could consider just taking it off and checking inside it for pieces of metal. I'd probably leave the oil pan and timing cover alone unless you have oil leaks. If you decide to remove anyways, it would be a good time to replace the crankshaft seal in the timing cover.
Yeah, that's right. My name is Randy too!
WWW.Randysrods.freeservers.com
1970 Chevy C-10 shortstep
30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast!
87 Harley Sportster(couldnt get a 350 to fit)
Self Propelled Lawn Mower
Built in USA!!!!
Virginia Beach, VA.
Randy70C-10 is offline   Reply With Quote
Old 05-16-2002, 04:08 PM   #4
Riptide
Post
Points, condenser, and dist. cap. Rotor button if it's an hei. Check the plug wires and plugs.
67 Chevy C10
McPherson, Ks
67 Chevy C10
McPherson, Ks
"Remember Don't Sweat the Petty Things, Pet the Sweaty Things"
Riptide is offline   Reply With Quote
Old 05-16-2002, 04:29 PM   #5
Gordo
Post
Fresh hoses, upper and lower radiator and heater.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
