04-08-2009, 02:33 PM | #1 |
Old Heap Driver
Shocks for a bagged front end
What shocks are you guys with bags running on the front?
I've looked at drop shocks, building a new upper mount, etc. I've searched and read so much it's all running together. Help!! Thanks! Bryan
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
04-10-2009, 05:46 AM | #2 |
Old Heap Driver
Re: Shocks for a bagged front end
Anyone?
04-10-2009, 07:59 AM | #3 |
One day...
You will have to find a shock that wont bottom out when aired out and that you wont pull the guts out of if you raise it all the way. you can use toxics or something like that, a friend of mine just uses monroes from local parts stores because they wont last as long compared to a factory suspension and they are easy to come by asap. Hope that helps a bit.
04-10-2009, 08:13 AM | #4 | |
Old Heap Driver
Looks like building a new upper mount is the way to go.
04-10-2009, 09:46 AM | #5 |
I have bell tech on mine
04-10-2009, 06:54 PM | #6 | |
One day...
04-10-2009, 07:04 PM | #7 |
Seņor Member
This would be a good opportunity to try out the search feature. There are a half dozen really informative threads on this very subject.
04-10-2009, 08:51 PM | #8 | |
Old Heap Driver
Thanks for the suggestion though.
04-10-2009, 09:05 PM | #9 | |
Old Heap Driver
If I build an upper mount that raises the mounting point 3-4" I should be good with a stock over the counter shock.
04-10-2009, 09:15 PM | #10 |
Redefining LowBudget
Dodge dakota!!!!!!!!
04-10-2009, 09:28 PM | #11 | |
Seņor Member
04-10-2009, 10:13 PM | #12 |
XXL your attitude does suck...but I feel the same pain and I like the 'tude sorry for the hi-jack..............
CHEVY ONLY |
04-10-2009, 11:05 PM | #13 |
Resistance is Futile
Well I'll throw ya off track.....I just picked up a bunch of budget S10 parts including an air set-up for the front. I asked the guy what he used for shocks and he said he didnt run any!!!!!!! 98 extended cab 4cyl.....I cant confirm it, but he didnt have any shock brackets in the stuff he sold.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-11-2009, 11:53 PM | #14 |
I run nothing but Bilstein.
If you can find it cheaper, I can fix it! |
09-15-2009, 03:33 PM | #15 |
Seņor Member
bump
09-15-2009, 04:10 PM | #16 |
I set my Beater up for Bilsteins (replacement fronts & 88-98 rears using modified brackets). I'm curious how you choose rear shocks for your builds w/air set-ups. Do you have a select p/n you like or ??
09-15-2009, 05:04 PM | #17 |
Isnt there some bilsteins specifically for bagged trucks? All I could find searching the net was http://www.racecardynamics.com/class...ag/airride.htm
Adam M STX Designs Motorcycles | Choppers | Hotrods |
09-16-2009, 02:20 PM | #18 |
Those are the air ride shocks I use.
I order my shocks based on length, weight of the vehicle, suspension type (IRS, straight axle, really heavy straight axle, etc), and the weight of the wheels.
09-20-2009, 08:08 PM | #19 | |
IS there a book that list all the specs or just down at the auto parts store?
09-20-2009, 08:50 PM | #20 |
I am talking about the air ride shocks. I call RCD with the listed information, and they set me up with the correct shock.
09-21-2009, 10:11 AM | #21 |
i just bagged my back end last weekend and had to find shocks.
instead of trying to guess what type of shocks you need before you do the upgrade, you should really bag it first and then get your aired out and max height distances. once you have that you can go to napa, or an autoparts store that hires knowledgable people and they can find you a shock that matches those specs. i paid $33/each for my rear sensatrac shocks. i searched and searched the forum like you and everyone else with no luck. chances are your setup will be a little different than others so you maybe wasting money trying to guess on a correct shock and hope it works. |
09-21-2009, 10:43 AM | #22 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-21-2009, 12:21 PM | #23 |
Seņor Member
I reserve my spoonfeeding for people who've shown a little initiative on their part.
09-21-2009, 04:04 PM | #24 |
Happy to be here
Knock it off guys.
09-21-2009, 04:13 PM | #25 |
get out the ruler and start smacking knuckles Ken!
CHEVY ONLY Last edited by joe231; 09-21-2009 at 04:15 PM. |
