04-19-2009, 10:30 PM | #1 |
rudy67chevy
02 silverado hard to start when warm
my 02 silverado is hard to start when i park it. for a few minutes or hours after i drove it. A few block or a few miles. The truck acts like my old chevy, when i try to start it in the morning
04-21-2009, 01:12 PM | #2 |
Progress = 0%
Re: 02 silverado hard to start when warm
Have you checked the fuel pressure regulator? My truck had a similar issue and that was the problem. It's located on the driver's side of the engine and has a vacuum hose hooked to it. Pull off the hose (with the engine off) and if any gas drips out, it needs to be replaced. Just a thought and is easy to test.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
04-21-2009, 01:18 PM | #3 |
Mine did that when it was fairly new; started OK when cold but not when warm. Turned out it was faulty injectors causing flooding. Just a thought.
04-21-2009, 06:50 PM | #4 | |
04-25-2009, 03:33 PM | #5 |
Junior Member
I had the same problem. See my earlier post. It was the press reg. Put a fuel press gauge on it and see what the press is. I just pressed in the Schrader valve on the fuel rail and nothing sprayed out. I'm not sure, so you better check with the manual, but I think the press should be about 60 psi. Also, when I pulled the vacuum line, gas ran out. Replaced the press reg and it has been running fine now for 2 months.
72 GMC Sierra Grande SWB 402 BB A/C (Owned it since 1973) 99 Silverado 1500 LT with 315K miles (RIP) 2012 GMC Sierra SLT |
