04-28-2009, 11:01 PM | #1 |
Cheap 6 lug rear disc????
I have seen everyone making cheap kits work with impala parts etc but what can be done for the six luggers for cheaper. I can get the brackets,hoses and calipers for a metric car but what to do about rotors? I want discs all around but stay 6 lug and not spend 1200 on it. Front rotors alone are going to run me 86.65ea for 72 spindle. 12 bolt btw.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-28-2009, 11:08 PM | #2 |
60-66 Nut
Re: Cheap 6 lug rear disc????
I've thought about designing some brackets for 6 lug rear discs, but just haven't had the time yet. That and I'm not sure how many would want them.
On the ultra cheap, I've seen a guy re-drill the front backing plates from a K10 to fit the flange on the 12 bolt and use the rotor and caliper from the same. I don't remember the details or how well it all lined up though.
04-28-2009, 11:09 PM | #3 | |
04-28-2009, 11:53 PM | #4 |
4x4 S10's are 5 on 4.75 bolt circle, I believe....
CHEVY ONLY |
04-29-2009, 12:10 AM | #5 |
88-94 S-15's & Jimmy's (both 4x4's) were 6x5.5" pattern. I'm not sure about the disc option though (can't remeber what year they started offering rear discs).
04-29-2009, 07:49 AM | #6 |
so im guessing late model gm trucks rear disc rotors dont work ?
66 swb fleetside restomod |
04-29-2009, 08:12 AM | #7 | |
I'm looking up rotors for an 89 S-15 Jimmy 4x4...it has 5 on 4 3/4 bolt circle... i'll check some other years.... 94 is the same and no rear discs here is a pic
CHEVY ONLY Last edited by joe231; 04-29-2009 at 08:16 AM. |
04-29-2009, 06:55 PM | #8 |
I honestly didn't think about the chevy rears...Anybody know.
04-29-2009, 07:26 PM | #9 |
Resistance is Futile
I met a guy using a 99+ rear axle from a pick-up around here. Your issues are the width and your wheel backspacing. Also metric lugs.
As far as SCOTI's suggestion; I have never seen a 6-lug S10....only the newer Trailblazers, which is again a different pattern than our trucks.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-29-2009, 07:30 PM | #10 |
sooo...SCOTI....you been hitting the crack pipe extra hard lately?
CHEVY ONLY |
04-29-2009, 08:12 PM | #11 | |
Look @ the far left column (S.No). Scroll down to #89 & compare it to #90 . . .... http://www.rimhelp.com/searchrecords...ype=&page_no=2 Put that in your pipe & smoke it.
04-29-2009, 08:19 PM | #12 |
Looking for pics now....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-29-2009 at 08:22 PM. |
04-29-2009, 08:40 PM | #13 |
If you re-read my initial post there was a question mark after my statement because I'm not up to speed on S-10 4x4 Blazers. I did know a guy that had a s-10 Blazer 4x4 back when I was going to school & it had 6-lug wheels. When I first read this thread, I remembered his truck & looked it up (googled). I came across that site & figured it was a 4x2 vs. 4x4 thing.
Upon further investigation, most of the stock wheels I've seen/searched for were indeed 5-lug pattern. I do remember his truck looked pretty stock-ish & I thought the wheels were OE. I guess he did some swapping on his . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-29-2009 at 08:43 PM. |
04-29-2009, 11:40 PM | #14 | |
60-66 Nut
I have a couple of ideas but just haven't had time to get it worked out.
04-29-2009, 11:57 PM | #15 |
My goal is to run 17x9 all around, wifes idea. I want 17x11 and 7x9
04-30-2009, 10:25 AM | #16 | ||
(and my friends do call me "DICK" ) I am thinking whom ever compiled the bolt pattern list may have mistaken a full size 4x4 GMC Jimmy (blazer equivalent) with 6 lugs for a 4x4 S-15 jimmy with 5 lugs...dunno but it was in no way an attack on your character....you provide very good info and are appreciated by me at least, and I'm sure many more members.
CHEVY ONLY |
04-30-2009, 11:54 AM | #17 | |
04-30-2009, 12:53 PM | #18 |
Have you reseached the isuzu corporate 12 bolt? It has a 6x5.5" pattern. I thought gm and isuzu were in cahoots?
I suppose this is what they go for http://dallas.craigslist.org/dal/pts/1102531174.html I also heard they have limited slip. Last edited by Joemomma1; 04-30-2009 at 12:58 PM. |
04-30-2009, 01:17 PM | #19 |
that isuzu might be the way to go.....anyone know the wms-to-wms on the stock rear end in the 4-5-6 trucks?
CHEVY ONLY |
04-30-2009, 08:11 PM | #20 |
I would think stepping down to the d44 wouldn't be worth getting disc brakes plus parts are more expensive for dana stuff. I dont think it would handle getting beat on when I get my other motor done.
04-30-2009, 10:33 PM | #21 | |
60-66 Nut
The '63-'69 12 bolts measure 62 1/8" wms to wms. I just recently read that the 1970 12 bolts are slightly wider. Anyone else heard that or can verify that claim?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-30-2009 at 10:34 PM. |
05-01-2009, 12:20 AM | #22 |
Cap'n.....I have a 68 rear and a 71-2. The 71-2 is wider cuz my wheels fit on the burb and I had to tub the pick-up with less backspace. Rather unscientific but I'll try to get out the tape to measure. The newer rears are supposed to be 1.5'' wider total.
05-01-2009, 11:52 PM | #23 | |
60-66 Nut
Yes I was aware that starting in '71 the differentials are 1.5" wider than previous years, but I recently read that the '70 model was either the same width as the '71 and newer or somewhere in between. I just don't know if that info is correct or not.
05-02-2009, 12:11 AM | #24 |
....we mite have to hang out with the 67-72 crowd for awhile.
05-03-2009, 08:42 PM | #25 |
I called these guys http://www.ruffstuffspecialties.com/catalog/index.php a few days ago and they said that they are working on a disc brake setup for the small bearing 12 bolt rear end...hope this helps a little...I will probably be getting this as soon as they finalize their design
