Old 05-03-2009, 12:20 AM   #1
buildinga55
88 SBC in 48 Pickup Questions on belts and brackets
I am planning to put the 88 Carburated 350 in the 48 Chevy. The brackets and all accessories were off the engine when I got it. I am not really planning to use the serpintine setup and was wondering if anyone had pictures of the V belt setup for the Power Steering and Alternator. May run a/c later, but not worried about it right now. All the brackets are in boxes so it makes it kind of tough to figure out what goes where. I am pretty much in the mock up stage, just wanting to make sure everything fits. Thanks for any advice and pictures.
buildinga55 is offline   Reply With Quote
Old 05-03-2009, 10:12 AM   #2
54 jimmy
54 jimmy's Avatar
Re: 88 SBC in 48 Pickup Questions on belts and brackets
mine is the older sbc but i'm pretty sure they are the same. here a pic of mine hope this helps
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-03-2009, 10:37 AM   #3
buildinga55
Thanks, that picture is helpful. Looks like the long water pump setup which is what I have. Did you pulleys have a v groove and a serpintine groove? I will print a copy of your picture and see if I can get this figured out. I assume you have room for the fan or were there any modifications to use a standard style radiator?
Old 05-03-2009, 01:07 PM   #4
buildinga55
Any chance you have any pictures from the side and/or back of the PS unit and Alternator? I apparently do not have all the brackets that were suppose to come with this engine. Thanks
Old 05-03-2009, 01:10 PM   #5
buildinga55
One other thing. The PS pulley is bent. Does anyone know how do you get this pulley off? I have used an allen wrench and pipe wrench to try to get this thing off, and it will not budge. Thanks
Old 05-03-2009, 02:21 PM   #6
solidaxel
solidaxel's Avatar
You will need the proper tools to remove and install the pulley.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-03-2009, 02:45 PM   #7
dan76
If I recall, a press is best for removing this pulley.
dan76 is offline   Reply With Quote
Old 05-03-2009, 06:17 PM   #8
solidaxel
solidaxel's Avatar
If you have a checker or Cragen Auto parts store they will rent, loan you the puller, it is also the installer tool.
LS 3 4L70E
350 brackets ps
