Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-07-2009, 12:30 AM   #1
GMC70c20
how wide of a tire will fit
How wide of a tire will fit on a stock width rear end, before it rubs the leaf springs in the stock position but still fit inside the box wall (I will probably cut the stock wheel wells out)?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 05-07-2009, 07:44 AM   #2
djracer
djracer's Avatar
Re: how wide of a tire will fit
I don't know about a leaf truck but if you swap to trailing arms you can fit a huge tire. I had a 71 with no mods to the wheel wells and had 28x12.5 sportsman pro m/t's on it with a 10 inch wheel.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-07-2009, 10:12 PM   #3
drag_72
Ready to go fast!!
drag_72's Avatar
i have the same question!!! what tire would fit with trailin arms and cut out wheel wells?
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 05-07-2009, 10:20 PM   #4
71Dragtruck
71Dragtruck's Avatar
29x14.5/15 Hoosier Quicktime Pros on a 15x12" rim with 7.5" backspace will fit trailing arms and cut fenderwells, stock rearend.
http://67-72chevytrucks.com/vboard/s...d.php?t=276897
here is a old pic of my truck with this combo.
Narrowed rear I now run a 31x16.5" Mickey ET Street with lot's of room.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-07-2009, 10:29 PM   #5
71Dragtruck
Here's a pic of the new tires.
Sponsored by:
Hard Candy Customs
Old 05-07-2009, 11:44 PM   #6
Nolowrider
Nolowrider's Avatar
I have M/T 29x15R15 with 6.5 inch backspace, fits fine with about 1 inch from leaf spring.
The pic in my signature is old and without the new tires.
Nolowrider is offline   Reply With Quote
Old 05-08-2009, 07:18 AM   #7
djracer
djracer's Avatar
What kind of tubular control arms are those?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-08-2009, 09:44 AM   #8
71Dragtruck
I can't remember for sure, thinking they are CPP if my memory is right, I bought them from a board member that went with air bags instead.
Sponsored by:
Hard Candy Customs
Old 05-08-2009, 11:49 AM   #9
scatesracing
Machinist
scatesracing's Avatar
A friend of mine has 29 18.5 MT under his ...... its so close but there under there
scatesracing is offline   Reply With Quote
