Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-12-2009, 10:49 PM   #1
tomtuna1978
big block cam question
dose any one know the max cam lift you can run with stock stamped rocker arms ? even with the elongated rockers i think u can only run like a .600 in lift... dose any one know this ?
tomtuna1978 is offline   Reply With Quote
Old 05-13-2009, 03:58 AM   #2
Ford Assassin
Ford Assassin's Avatar
Re: big block cam question
No stamped steel rocker for BBC (elongated or not) I've ever heard of is suppose to be used the cams over .550" of lift, .600" would be pushing it IMO.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 05-13-2009, 11:06 AM   #3
tomtuna1978
thanks fordassassin
