Old 05-13-2009, 09:54 AM   #1
scruffre
scruffre's Avatar
Question Auto to standard trans swap
I have the chance at complete 4speed set up out of an 86 1/2 ton 4x4. I was wondering if it would be a major job to swap out the 3speed auto and put the 4speed in my 78 Blazer?
scruffre is offline   Reply With Quote
Old 05-13-2009, 03:25 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Auto to standard trans swap
It's a lot of work, but it can be done. I bet someone will pop up on here that has done this before.
Anyone?
tvblazer78 is offline   Reply With Quote
Old 05-15-2009, 08:45 AM   #3
scruffre
scruffre's Avatar
Forgot to mention that the Blazer has a 305 and the truck has a 5.7 (350) if that makes any difference
Old 05-15-2009, 01:25 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
One of the biggest things to check is, see if the 86 has a 1 piece rear main seal or not. The 1 piece seal's flywheel is different than the one for a 2 piece seal like your 78 should have. The 86 should also have a hydraulic clutch setup where the 78 would have a push rod and z bar setup. The motor size difference will not affect anything...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-23-2009, 06:40 PM   #5
scruffre
scruffre's Avatar
Found out a bit more about the 4speed. It is hooked up to a 305 and the truck was an auto to begin with. I'm going out to have a look at it on Sunday and have a better look at what all will be involved in a swap. Wish me luck LOL
