Old 06-03-2009, 01:40 AM   #1
**grumpy**
**grumpy**'s Avatar
Manual valve question
A few years ago I had a 59 Chevy wagon that was bagged.
It was only 2 switch, 1 front 1 back.
It used some kind of manual paddle valves. The valves were on each side of the center console and the air escaped into the console when airing it out.
Any idea if theres something like that available thats not expensive?
I see some on ebay for 20 bucks each, but not sure how they work.
I just want to bag the front of my torsion bar equipped 60 shortbed, to do away with the torsion setup.
Money is a real issue right now. Cheap cheap cheap is what Im after to get me by for awhile.
Road Hounds
**grumpy** is offline   Reply With Quote
Old 06-03-2009, 07:44 AM   #2
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: Manual valve question
cheapest set-up I have seen used if you have a sway bar is two bags tee'd to a schrader valve. of course if your not near a gas station or other source of air when you need it.
I have a friend that is runnin like this but also tee'd in a small compressor , like a thomas 315/317 on a momentary push button. no tank or pressure switch. It is obviously slow to lift off the compressor so he usually airs up with a tire chuck on the valve and uses the compressor if he's somewhere without air.
Not sure I have the patience to hold the button down for 1-2 minutes while the truck airs up but it has worked for him for over 10 years without fail and is CHEAP.
for the panels like you describe Firestone still sells them as an accessory to their ride rite line of helper springs and I have pieced panels together using Clippard mini-matic button valves from my local hydraulic/pneumatic supply house. depending on orofice size they can be pretty cheap too.
Master Image Customs used to sell a ton of the manual panels back in the day so you might find something on ebay,garage sale, swap meet that could be pretty cheap too.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 06-03-2009, 10:38 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I understand the need for cheap, but your going way backwards. There are too many reasonably priced alternatives to go backwards.
Do some shopping on the minitruck sites. The younger guys are always getting in a financial bind and selling stuff of cheap.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-03-2009, 02:38 PM   #4
edflores
hey. i take offense to that. ha.
but try the s10forum classifieds. always a good deal on there on air stuff
edflores is offline   Reply With Quote
Old 06-03-2009, 03:59 PM   #5
c10addict
c10addict's Avatar
I think this would be the best/cheapest way to go... Good seller too... I was at his shop last week... man he's got some cool stuff..
http://cgi.ebay.com/ebaymotors/AirRi...Q5fAccessories
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 06-03-2009, 11:20 PM   #6
**grumpy**
**grumpy**'s Avatar
Yeah, I know Boris. I talked to him about that setup, and he says he uses it alot on all the X-frame cars they do. May be the route I take.
Road Hounds
