06-10-2009, 02:07 AM | #1 |
aluminum radiators
whats the biggest aluminum radiator yall have fit without any serious modification to your truck? and where did you get it from? i have been looking at this one
http://store.summitracing.com/partde...5&autoview=sku has anyone used it? |
06-10-2009, 07:43 AM | #2 |
and a few others
Re: aluminum radiators
this is what I used. Fits nice, you just have to rework the mounts a little. I assume you're running a SBC?
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
06-10-2009, 09:20 AM | #3 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-10-2009, 11:31 AM | #4 | |
06-10-2009, 04:36 PM | #5 |
and a few others
Mine is sitting just above the lower lip that sticks inward. I have about 1/2" clearance on both sides.
06-10-2009, 08:40 PM | #6 |
100% gearhead
I also used the 27X19 Northern. Fit great and with the Z in the frame, I used the stock upper bracket too!!!! Love that radiator. Get one.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
06-10-2009, 11:14 PM | #7 |
1 thing at a time is progress.
Great info
Alan
Philippians 2:14-16 |
06-14-2009, 10:19 PM | #8 |
what about you guys with 500+ horsepower, i cant seem to find anything that says its rated for more than 400 horsepower.
06-14-2009, 10:41 PM | #9 |
I would think the radiator might offer improved efficiency w/larger internal tubes (2-rows @ 1.25" vs. 1"). Other than that, the fan/shroud combo would be a good place to improve the efficiency.
06-18-2009, 10:27 AM | #10 |
Has anyone used on that is 25.5'' wide, 22'' tall and 3.25 inches thick.
06-18-2009, 11:23 AM | #11 |
I got one off ebay that was half the cost of Summit's, and it came with an electric fan. I'm very happy with it; and the $200 I saved!
My 68 cougar restomod build:HERE |
06-18-2009, 12:33 PM | #12 |
The aluminum radiators we use are a direct bolt in using the stock holes on the core support for the fan shroud. They fully polished with dual Spal fans mounted to a polished fan shroud. Sorry it's hard to see in the picture!
06-18-2009, 12:46 PM | #13 |
oops!
06-18-2009, 01:06 PM | #14 |
More info.... Who do you use? P/N's? Specs?
06-18-2009, 06:58 PM | #15 |
You got one for $9...
06-18-2009, 07:03 PM | #16 |
This one has no cooler. http://www.summitracing.com/parts/SUM-380428/
This is the one that you see in the pictures of my truck. http://www.summitracing.com/parts/SUM-381428/ It has a cooler and some fab work is nessesary. I have only fitted the radiator and have not run any hoses yet. I have no idea how hard that is going to be. Direct bolt in is alot easier.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 06-18-2009 at 07:04 PM. |
06-19-2009, 01:17 PM | #17 |
I am running a griffin alum radiator with dual spal fans and trans cooler in my 64 pick up. I measures 26''wd x 22'' high x and 3'' thick. These are overall measurements. I am running a ls1-4l60e combo.
06-19-2009, 04:12 PM | #18 |
Ah ha, no. It was for my Cougar. The direct bolt-in one is a lot more expensive. The cheapest one I saw was just under $500. So... I saved more than $200 I guess.
This being said, I just recieved my ebay aluminum radiator today for the 65 GMC via UPS. It doesn't fit worth a crap, and I can't return it. I don't even know what it's supposed to go in, so that I can resell it. It's about 4 inches too wide, and hits the frame almost 3 inches before it sits into the rubber mounts. Oh well. Maybe I can trade it to the local radiator repair guy to re-core my original...
My 68 cougar restomod build:HERE Last edited by SeanPaintsFlames; 06-19-2009 at 04:13 PM. |
06-19-2009, 07:42 PM | #19 | |
06-19-2009, 10:40 PM | #20 |
I got it figured out. There are two pairs of holes for the bottom brackets. One high and one low. Mine was in the low location, to fit between the frame. I didn't want to get cutting and welding on my junky truck, but after a few minutes with the tools, it was in. I had to re-fab the top bracket bracing, too. Honestly, the most difficult and time-consuming part was finding different shaped radiator hoses to accommodate the wider spread between the hose inlets.
Those big rivets SUCK! You'd think it was a battleship.
06-20-2009, 12:48 AM | #21 |
Resistance is Futile
I used the SUM 380428 that Chevy Fleetside linked. I also picked up a B&M tranny cooler, stacked plate, 20,000GVW that I plumbed in. They both work great.....190* all day in 100*+ temps.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-20-2009, 09:13 AM | #22 |
Do you know the part #'s of the hoses you used or maybe an application? I wonder if it would be the same for tha BB if you are running a SB.
06-20-2009, 12:13 PM | #23 |
http://www.griffinrad.com/
A pal of mine had a warmed up sbf 302 in his '68 fairlane... and he just ordered one of their pre-made size radiators and made it fit with some brackets. They also have made to fit and custom fit to your applications... but that all depends upon your $$$$. -W Last edited by Woogeroo; 06-20-2009 at 12:16 PM. |
06-20-2009, 02:08 PM | #24 |
I just found out last night there's a new part from BCool, supposed to be a direct bolt in for our trucks. Saw it in a 65 step here in San Antonio, looks like it fits ok, but the owner said he had to cut the lower mounts some, and run another trans cooler, the openings in the BCool rad are inaccessible. I'm going to look into that one, and call to see if they've addressed any of his issues.
Wide open 'til you see God... Then brake! 1964 SWB Stepside, 355, powerglide, posi 1999 Dodge Ram 1500 Extended Cab 4x4 2007 F@#$ Focus ST |
06-20-2009, 03:01 PM | #25 | |
