Old 03-24-2002, 07:41 PM   #1
chucks70
Post master cylinder question for disc conversion.
Got a master cylinder and the rest of a disc brake setup from a 91 Burb. The discs bolted right up especially since I got the the spindles off the donor. Had to re route the lines through the frame. Brake have power boost, the smaller one that sticks way out past the cowl. The 91 master cylinder won't accept the "push rod" from the booster, the rod is too long by about 2 inches. The 70 master cylinder end has a deep hole recessed in it to take the rod, the 91 is almost flush with the end. Can I use the original master cylinder with the 91 proportioning valve or should I try to find a compatible master cylinder for disc brakes?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 03-24-2002, 07:46 PM   #2
slam33
slam33's Avatar
Post
the 91 might be metric
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 03-24-2002, 07:55 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
done use 91 anything on firewall, find a 67-72 booster and get 71 72 master cylinder
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
