Old 07-16-2009, 08:39 AM   #1
47guy
65 on a 73 to 87 frame
hello everyone im new to the site and i am about to start building my 65 chevy c10 lwb it was my first truck had it for 10 years and hasnt been toughed in about 8. so my question is what do yall think would be the best way to go either shorten my existing frame or to put my body on a 73 to 87 short wheel base frame? thanks for all the input in advance.
47guy is offline   Reply With Quote
Old 07-16-2009, 11:20 AM   #2
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: 65 on a 73 to 87 frame
check out strodder's build thread
link
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-17-2009, 03:22 PM   #3
Captainfab
60-66 Nut
Definitely shorten your existing frame. If you mount your '65 body on a '73-'87 frame you'll have to make all new frame brackets for the body mounts and it will end up with a body lift. It will sit about like a stock K10. BTDT
If you're wanting front disc brales just swap the suspension from a '73-'87 to your '65 frame. Much easier and better IMO. For the rear you can either swap the '73-'87 differential into your truck or get 5 lug conversion axles for your '65 differential.
Old 07-24-2009, 09:53 PM   #4
47guy
thanks for the input i already did the front end swap with a 82 model about 8 or 9 years ago i have decided to keep it a long wheel base and i hope to have it home this week to start working on it again ill post pics when i get it home and start tearing it apart.
