07-20-2009, 10:04 AM | #1 |
Doing it my damn self.....
Frame Cleaning Solution found!!!!
Greetings Gearhead Collegues...
While tearing down my baby I was dreading the ineviatble frame cleaning and detailing. I read a couple of threads about oven cleaner from the dollar store. I was in extreme doubt about using this on my frame and the power it would have aginst 40 years worth of grease oil, grime, salt, etc, etc. This stuff works wonders!!! I had a very thick build up of "funk" all over the frame from leaks from everywhere literally. I caoted the entire frame with the oven cleaner..(3 cans) and let it sit and work for 1 1/2 hours. I fired up my pressure washer and actually sprayed the frame clean!!! I was in awe at the power of the oven cleaner. Now I'm down to business on blasting my frame and finishing it off by primer and paint. All of that cost me $3.00 and a little water. I figure some guys projects might be at the same status as mine and looking for a cheap frame cleaning solution and wanted to pass along for what it's worth. Keep the projects going..
Mark... Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761 69 C10 Stepper - Current Build 94 Silverado - Driver 05 Hummer H2 - Unique Whip |
07-20-2009, 10:14 AM | #2 |
low n' slo
Re: Frame Cleaning Solution found!!!!
nice, you take any pics by any chance?
07-20-2009, 11:16 AM | #3 |
Sounds like a winner! Any particular brand of oven cleaner?
07-20-2009, 11:22 AM | #4 |
the cheaper the brand the better ... Dollar General store brand works awesome ... be sure to wear gloves and eye protection
07-20-2009, 11:58 AM | #5 |
Definitely true words of wisdom. Outside breeze will easily carry this stuff. If it gets in your eyes or on your skin, you'll be very uncomfortable for several minutes @ the minimum.
07-20-2009, 12:15 PM | #6 |
07-20-2009, 08:36 PM | #7 |
Hi Gents,
I took a couple of after pics when I used the oven cleaner. I didn't have the forethought to take any before pics but, believe me, it was absolutely funkified with grease, grime, and nastiness. The oven cleaner is from the Dollar Store and is nothing short of amazing. 1 application did the trick (3 cans) did the entire frame. Followed by a pressure washer and presto, ready to blast, prime and paint. Thanks, Mark Ingle Asheville, NC
07-22-2009, 01:10 PM | #8 |
James
Yes, this stuff works wonders. I recently used it on my latest project thinking it could never work and it did better that anything else I've tried. And gloves are an absolute MUST to use. My finger tips especially around my nails were soooo chemical burnt it was rediculous. I always have to learn the hard way it seems.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
07-22-2009, 02:28 PM | #9 |
Try not to get it on aluminum for very long
nickle and dime |
07-22-2009, 07:58 PM | #10 |
chrome makes it go FASTER!
Also works great for de-greasing motors.
Does a kick azz job on a dirty BBQ grille too!
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
07-22-2009, 08:17 PM | #11 |
Never had it to be harmful to aluminum ... the anodizing on the other hand will be removed.
07-22-2009, 11:22 PM | #12 |
I would suggest at the very least a dust mask, but next time I am getting out the paint respirator...I got a good lungfull the other day,it's not alot of fun. But I did get the engine bay clean"er"
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-22-2009, 11:36 PM | #13 |
Tot Roddin'
There's also Simple Green... it works!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-28-2009, 11:52 AM | #14 |
Does. It workfor. Rust?
07-28-2009, 09:02 PM | #15 |
It left the rough rusty spots but, you'll be impressed with it.
07-29-2009, 01:07 AM | #16 |
I have a good amount of surface rust. Any tips?
08-01-2009, 12:10 AM | #17 |
Under Construction
sand, and then paint with por-15
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-01-2009, 05:21 PM | #18 |
as in sand it? or sand blast it?
08-01-2009, 08:53 PM | #19 |
Sand Blast would be the best
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
08-02-2009, 11:55 PM | #20 |
okay any thread you can direct me to that would help on the art of sand blasting? haha
08-03-2009, 07:15 AM | #21 |
I'd do a search for one. It seems like somebody posts one up in the paint and body section on a monthly basis. Also, there is a nozzle that you can put on a pressure washer that basically acts as a jet-pump and you can use it to sand-blast just about anything. The only down-side to it is wasted sand...but sand is relatively cheap.
08-04-2009, 10:04 AM | #22 | |
Food for thought....good luck on your project.
08-04-2009, 01:46 PM | #23 |
what type of shop should i look for and what price should i look to spend?
08-04-2009, 03:34 PM | #24 | |
Just to give you an idea, to blast my frame he was going to charge between $150 and $200. That was the best deal I found. Most shops was going to charge between $80 and $90 per hour. I like the flat rate better, no surprises at time to pay you know.
08-04-2009, 03:44 PM | #25 |
okay. sounds good. can they just paint it with a black gloss after the prime. and if so will it be that much more expensive? and can they do just the back of the frame. i know it sounds weird but im doing a daily driver build and i took off the bed to replace the bed and im just doing that part right now.
