Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-26-2009, 08:53 PM   #1
JW76
JW76's Avatar
12 bolt
I have a 12 bolt out of a 1969 truck with 3.73 gears. I am putting it in my truck with a TH400 with a manual valve body. I will eventually build a 6.0 that makes 500 - 550 torque for the truck. Will the 12 bolt be able to take the abuse? The truck will mostly see street use with occasional runs at the track. I've heard that the pinion shafts are smaller than the cars and break quite easily. I intend to use good Moser axles and a C clip eliminator kit if I use the 12 bolt. Thanks for any input.
JW76 is offline   Reply With Quote
Old 07-26-2009, 09:18 PM   #2
69trk
69trk's Avatar
Re: 12 bolt
mines holding up. I changed to 33 spline moser axles with c-clip eliminators and a full spool.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 08-02-2009, 08:52 PM   #3
70 net440
Junior Member
70 net440's Avatar
Re: 12 bolt
Are the c-clip eliminaters the same for the truck 12 bolt as the car 12 bolt?
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 08-02-2009, 09:07 PM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: 12 bolt
I have the 35 spline spool and axle package from Moser leaving on a trans break. They have held up fine. About the ring and Pinion you can use a car gear in truck Housing but it takes conversion bearings. I believe randy's ring and pinion has all the numbers.
68 C-10 KID is offline   Reply With Quote
Old 08-02-2009, 10:10 PM   #5
70 net440
Junior Member
70 net440's Avatar
Re: 12 bolt
Good info. I'll probobly go with a posi instead of a spool so I can keep the truck streetable.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
Old 08-07-2009, 05:10 PM   #6
68 C-10 KID
Mean Green
Re: 12 bolt
Oh come on, I drive mine all over town down the free way w/ 28x13.5 M/T
LOL cool good luck.
I recommend the Moroso unit or Eaton. They bite hard but plenty of street ability.
Old 08-08-2009, 06:03 AM   #7
71chevytruckguy
71chevytruckguy's Avatar
Re: 12 bolt
Mark Williams is makin a 33 spline posi so you can run stronger axles. Its for a car 12 bolt but I think it should work in a truck. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
