Old 01-08-2003, 05:09 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
ZZ502 and Headers
Has anyone had any luck finding headers that will fit a new ZZ502 by cleasing the head bolts. I called Hooker and they said that you have to grind the flange off of the header to get it to clear.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 01-08-2003, 10:55 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
I didn't know they were differnt from other big blocks
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-08-2003, 11:01 PM   #3
Custom 68
Custom 68's Avatar
what is different from the "standard" 502 my boss has one in a GTO with hooker ceramic headers .
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 01-08-2003, 11:37 PM   #4
72ChevyCheyenne
The ZZ502 has oval port aluminum heads. The angle of the head bolts don't allow enough room for the flange to sit behind them.
Bill Durham
72 Cheyenne
