Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-02-2009, 03:11 PM   #1
Garagedude
Garagedude's Avatar
Finally Getting There
Got the cage all done, back window in working on finishing all the aluminum and really detailing the truck, been driving it around on the streets its been alot of fun.
Garagedude is offline   Reply With Quote
Old 08-02-2009, 03:12 PM   #2
Garagedude
Garagedude's Avatar
Re: Finally Getting There
pics should come up
Old 08-02-2009, 03:13 PM   #3
Garagedude
Garagedude's Avatar
more
Old 08-02-2009, 05:02 PM   #4
gene_ensor
gene_ensor's Avatar
Awesome!
Can you provide details regarding rear tire make and size, rim size and back spacing, axle width (Moser P/N's etc), mosier axle housing(???), rear brake option, any modification to frame or axle bump stops, any issues with brake cable or hose interference with rim etc, source and P/N for ebrake cable, p/n and source for tubs, and finally, how much space do you have between the wheel and the frame/sheet metal. Pictures would greatly be appreciated. Mocking all the stuff up is expensive and am trying to minimize cost on my end. Thanks!
gene_ensor is offline   Reply With Quote
Old 08-07-2009, 08:48 PM   #5
Garagedude
Garagedude's Avatar
Sorry it took me so long to get back to you, i have busy with work and school my day starts at 6am and I don't get home till 11pm its been crazy. The tires are Mickey Thompson 29x18.5, on weld racing 15x12 rims, with a 7.5 inch backspacing, the rearend is a 12 bolt out of a 79 camaro it has wilwood 4 piston caliper brakes, richmond 3:73 gears, eaton posi, bearing support pan, and a set of axles. I have about an inch and half between the tub and the tires. Its all stock suspension just drop coils and shocks.
Old 08-07-2009, 09:35 PM   #6
gene_ensor
gene_ensor's Avatar
Excellent! If you ever get your tires off, I would be very interested in the axle width.
Old 08-09-2009, 12:53 PM   #7
Garagedude
Garagedude's Avatar
Next time I have them off I will measure, I am trying too finish the truck right now and sell it, I am ready too move on to a new vehicle, I have court again thursday I should have already lost my licence this year so I guese you could say I need to get away from the whole fast car thing for a while.
