08-07-2009, 08:50 AM | #1 |
Guage help
I have a Autometer Pro Comp mechanical oil pressure guage.The truck has been apart for a few years and am now almost ready to fire the new engine.When I went to check everything the guage showed 25lbs,that was before it was hooked up,so it must have been like that since the other engine was in.When I primed the BB the guage moved to show pressure,but when I stopped priming it returned to 25 lbs.Is there a way to zero the guage,or is it time for a new one, Thanks Brian
08-07-2009, 10:11 AM | #2 |
Registered Truck Offender
Re: Guage help
Sounds to me kile it got droped. Had one do something similar shen it smacked the concrete.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-07-2009, 11:34 AM | #3 |
Re: Guage help
That would make sense Marv,but its never been out of the dash and it worked fine before.It must have been stuck at 25 when I took the small block out.
08-17-2009, 11:05 PM | #4 |
2WD Jimmy
Re: Guage help
Call Autometer. Theyre great people.
08-17-2009, 11:20 PM | #5 |
Re: Guage help
Yes they are,most stuff is lifetime but don't know about OP
Built chevy tuff! |
08-18-2009, 09:01 AM | #6 |
Re: Guage help
I took the gauge out and it returned to zero,put it back in same problem.Then I pulled out the light and it went back to zero,I guess the bulb must have been contacting inside the guage,smaller bulb problem fixed.Hope this helps someone else,I almost feel stupid lool, thanks for all the help
