08-07-2009, 06:29 PM | #1 |
Wiw:
this is sitting at my work at a body shop here in town... and its been sittin there since i started working there about a year ago.. its been sitting there longer because i remember seeing it before i started working there... anyways is this a longbed or shortbed? i cant tell.. reason i want it is because its 4wd.. i would love to redo it... its got no motor or trans.. only thing it has is a rolling frame with a cab sitting on it as you can tell... what would you guys give for it?? my boss said this guy would probably sell it.. so what do i offer cash wise? and i dont have the vin to tell me what exact year it is
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
08-07-2009, 06:30 PM | #2 |
Re: Wiw:
dang my camera phone is really good
08-07-2009, 06:33 PM | #3 |
67-72 parts collector,…
Re: Wiw:
I would say lwb.
Look on the SPID sheet in the glove box. The wheelbase for a short bed it 115",... and 127" for a long bed.
08-07-2009, 06:40 PM | #4 |
Re: Wiw:
no spid since there no glovebox door.. do i just go get the vin and run that? what would u pay?
08-07-2009, 06:45 PM | #5 |
Re: Wiw:
I would pay no more than $100 for it for just the axles and wheels. Rest has rust and is junk. It's going to cost you a small fortune to buy all the sheetmetal, the whole interior and entire drivetrain. It's going to be all the little missing items that will drive the budget through the roof. Yo can get a fairly cheap long block, but what about a cooling system, pulleys, steering stuff, accessories, charging system, starting system, etc. Might be better and cheaper in the long run if you had a cheap 2wd donor truck to swap parts from.
08-07-2009, 06:57 PM | #6 |
Re: Wiw:
Looks to be a 69 or 70 4 speed truck with 203 t/c it also looks to be a long wheel base truck but it is hard to tell from the picture. Pull a tape from axle to axle and get a measurement and compare to your other truck. You will not be able to tell from the vin if long or short. The running gear is worth more than 100 bucks and it is a 4x4 which is getting difficult to find.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
08-07-2009, 08:24 PM | #7 |
Re: Wiw:
Thats deff a long bed but im with the rest of the guys the body is pretty bad.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction 04 GMC 1/2ton daily 07 GMC Acadia wifes daily |
08-07-2009, 09:33 PM | #8 |
Re: Wiw:
You could take that truck to scrap yard and get more than a $100 bones for it.
08-08-2009, 08:39 PM | #9 |
Re: Wiw:
ill offer the guy a hundred bucks see what he says
08-10-2009, 07:31 PM | #10 |
Re: Wiw:
be sure to get a clean title......
