Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-16-2009, 10:41 PM   #1
travo77
travo77's Avatar
th400 problems
its a th400 with street strip shift kit brand new vacuum mod and i checked vac at carb and vacuum mod its around 10 but no matter what it will shift around 4000 rpm is that enough vacuum to operate or do i need more any help would be appreciated
travo77 is offline   Reply With Quote
Old 08-17-2009, 08:53 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: th400 problems
Who did the shift kit? sounds like a valve body problem. Was the governor modified?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-17-2009, 10:53 PM   #3
Rodms
Rodms's Avatar
Re: th400 problems
sounds like something may be stopped up,or they left something out,put it on jack stands and run it through the gears and see what it does.
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-20-2009, 09:54 PM   #4
travo77
travo77's Avatar
Re: th400 problems
im gonna check it out this weekend make sure the shift kit is done right, ill let yall know
