Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-22-2009, 11:30 PM   #1
noonzor
rear trailing arm suspension
so my 69 came with the trailing arm rear suspension and im just wondering, for those who are running with theirs still, how they like it.
debating whether to just buy an aftermarket trailing arm kit or should i go all out with the triangulated 4link.
the truck will be a street legal drag truck, trailered to the track but able to drive to local events and shows.
thanks,
Kyle N.
noonzor is offline   Reply With Quote
Old 08-23-2009, 12:55 AM   #2
Super73
Super73's Avatar
Re: rear trailing arm suspension
Most the time your going to get a "they work great with little modifacation"
There will be a few others that say go 4 link.
Personally I run the factory arms as do a few of the even faster guys. They can work very well with next to nothing for mods.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-23-2009, 08:19 AM   #3
noonzor
excellent. what kind of mods would you be talking about exactly?
Old 08-23-2009, 12:03 PM   #4
Super73
Super73's Avatar
In the videos and pictures posted I had:
Put a different spring in it with a block to lower it
Moved the upper mounting point for the rear shock (only to accomidate the slightly longer shock)
Made adjustable mounts for the front eye of the control arm: http://67-72chevytrucks.com/vboard/s...highlight=rear
Since then I have:
Made a 1 3/4" x .120 wall antiroll bar eliminating the factory one that was on it
Added spring pockets to the rear control arms so I could cut my springs further or allow me to use a non pigtail spring if I choose to swap it out.
Still need to swap the rubber bushing in the front eyelet for a set of polly ones I have.
Some weld the center of the arms together. I didn't.
Old 08-23-2009, 10:41 PM   #5
noonzor
excellent, thanks a ton man, that link is very helpful with the pictures. im definitly going to look into doing something like that with the adjustability.
How are you finding that set-up? Is it helping you hook up better? I see from your videos you got some tire lift up front so your getting some good traction to the back on the launch it looks like.
Old 08-24-2009, 08:26 PM   #6
69trk
69trk's Avatar
I have stock trailering arms. Planning on changing shocks and springs later. Best 60' so far has been a 1.58 on my set up, but now my slicks are about worn out. Super73 knows his stuff when it comes to suspension...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 08-24-2009, 09:46 PM   #7
djracer
djracer's Avatar
Keep your trailing arms!
Here's my trailing arms leaving on a 250hp shot of nitrous.
http://www.facebook.com/l.php?u=http...fd6b8b131a0fa5
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-24-2009, 10:01 PM   #8
noonzor
hahaha duude you were on passtime?? thats awesome!!
yeah you got me sold!! keepin the arms!!
Old 08-25-2009, 12:00 AM   #9
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
WT Deuce? That's fn Bad A. ALL right, I have ?'s
I'm about to invest and gear's and new tire size. I'm currently running 4:10 with a 28x10.5. I have TH400 w/ Brake (stall 4000) w/ brake on 4600. I would like to Launch hard and dip into the 11's. Current best is 12.0's
Thanks Mike
68 C-10 KID is offline   Reply With Quote
Old 08-25-2009, 12:06 AM   #10
djracer
djracer's Avatar
I run a 4.30 gear and 33 x 10.5w tire. I would run more gear if I didn't have a bottle.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-25-2009, 12:26 AM   #11
noonzor
cool man, i just went through some of your build thread there and im just curious how you like your front suspension? i hear it can be a pain getting the steering lined up and workin proper. and another question on what exactly the rear suspension has done to it?
Old 08-25-2009, 12:55 AM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
Since then I have:
please enlighten us on this 'radius' drilling you did to the t-arm mounts. How did you measure/figure out how big of an arc to drill the holes on?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-27-2009, 09:26 PM   #13
blowncrazyer
blowncrazyer's Avatar
nice build! very nice build.....
you lift you lose
blowncrazyer is offline   Reply With Quote
Old 08-27-2009, 11:06 PM   #14
72 SUPER10
KEEP YOUR TRAIL ARMS , MINES NOT AS FAST AS SOME OF THE OTHER GUYS HERE, MINE WILL ALMOST GET ON THE BACK BUMPER WITH STOCK SUSP,ON THE TRANS BRAKE.
72 SUPER10 is offline   Reply With Quote
Old 08-27-2009, 11:28 PM   #15
djracer
djracer's Avatar
Thanks I can't wait to get it back together.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
