Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-23-2009, 08:47 AM   #1
Bears63
...just another truck junkie..
Bears63's Avatar
'63 C10 Parts - Updated List!!!
I am updating the parts list. What is listed below is what I have, if you don’t see it then I don’t have it so don’t ask. The prices below DO NOT include shipping. Pictures are available, but if more pictures are needed then please ask. It may take some time as I am very busy, but I will try to get some more. If a year is not listed then the parts are for a ’63, other years are noted. Finally, if you think my prices are out of line then make an offer and I will consider it. I am making guesses here.
Pictures for the following parts can be viewed right here.
60-62 Instrument Panel: Not sure of exact year, speedo is broken. $20
Steering Column Cover: Interior piece, slides over column. $15
Vent Assembly, right & left: $20 each
Glovebox Door w/ Frame: $20
Speedometer Cable: From 3spd truck. $10
Transmission Hump: From 3spd truck, cut for floor shifter. $20
Steering Wheel: Driver quality, chunk missing around horn button area. $20
Gas Tank w/ Filler Neck: Good shape, needs cleaning inside. $30
Steering Column Shaft: Only usable part of column. Will cut up if only a piece is needed. $20 for entire shaft.
Ashtray: $15
Steering Column Bracket: Holds column in place, e-brake handle mounts to this. $15
Clutch/Brake pedal assembly: I have 2 of these. $40 each
Clutch Rod: 2 available. $5 each
Deluxe Heater Interior Box: $20
Deluxe Heater Exterior Box: 2 available. One has been modified to accept 64-66 heater cores, other is in original condition. Does not include heater cores, blower motors included if wanted. $30 each
Hood Hinges: $20 for the pair
Hood Springs: $10 for the pair
Inner Fender Mounting Extensions: Used to connect inner fender to cab. $15 for the pair
Inner Fender Steering Cover: Filler panel for left inner fender. $15
Master Cylinder: Rebuildable, worked good when pulled. $5
Door Control, left: Ties handle to latch. $15
Door Strikers: One original, one older replacement. $15 for the pair
Hood Release: $20
Hood Latch: Post on panel that holds hood shut. $15
Door Hinges, left & right: May need bushings. $15 per side
Fender Spacers: Bolts to top of fender and spaces it out from the cowl. $15 for the pair
Accelerator Assembly: Bolts in the cab. $20
Cowl Extension Panel, right & left: Right side has antenna hole. $15 each
Tail Light Housing w/ Lens: Only one, no bezel. $10
Park Light Assembly: 2 available, w/ lenses. $15 each
Park Light Bezels: 2 available. $5 each
Heater Splash Guard: Bolts into cowl behind outside heater box. $15
Cowl Panel: $25
Radiator Support Covers, right & left: $15 each
Fan Shroud Panels: $30 for the complete 3 pc set
Fleetside Tailgate: Driver quality. Pics are right here. $25
Grille: Pics located here. What you see is what you get, rough but usable if you have time. $20
Hood: Pics are here. Driver quality, banged up, some bondo, some rust. $30
Front Bumper and Brackets: Pics are here. Great shape. Bumper is $40, brackets are $15 for the pair.
Grille Support: Pics are right here. Rough overall, but usable. Will cut up for patches if desired. $25
Door shells, left and right: Pics right here. Rough, need some work, but fixable. $25 each.
Pictures for the following parts are right here.
Hurst Indy shifter: For switching 3spd column shift to the floor. $15
Spark Plug Wire Loom: For use with headers. $10
I am also willing to cut patch panels from the good areas of the cab. Pics of the cab can be viewed right here. Let me know what area you need and how big of a panel is needed.
If you have questions about anything just ask here, by PM, or e-mail me at mshea43@hotmail.com. Thanks for looking!
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-23-2009, 09:48 AM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Parting out '63 C10 Longbed Fleetside
i would like the wiper link assembly it is what connects the wiper motor to the wiper arms mine one of the round caps that the wiper arm slides over is broken my zip is 14532 thanks!!!
gostranger is offline   Reply With Quote
Old 08-23-2009, 10:13 AM   #3
Bears63
Bears63's Avatar
I will get that pulled off today and I will take pics of it for you. I'll give you a price and shipping estimate at that time.
Mike "Bear" Shea
Old 08-23-2009, 10:25 AM   #4
49m
49m's Avatar
I want the V8 Engine Perches - $25/pair. Whats shipping to 40075?
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 08-23-2009, 10:27 AM   #5
49m
49m's Avatar
Does it still have the clutch bracket on the motor that goes to the frame?
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 08-23-2009, 10:38 AM   #6
Bears63
Bears63's Avatar
I still have all the clutch components. I'll do all the shipping quotes when I get back tonight. I am leaving in about an hour to go pull the parts but I'll check back here before I head out.
Mike "Bear" Shea
Old 08-23-2009, 12:06 PM   #7
terd ferguson
terd ferguson's Avatar
How about empty door shells? I don't need the glass, internal parts, hardware, or door panels. Just the door shells only. I'd need a shipping quote to NC 28025 to know if it's worthwhile price wise. Thanks in advance.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 08-23-2009, 12:21 PM   #8
Bears63
Bears63's Avatar
Just a warning on the doors, the bottoms are pretty rusty. I will take some good pics of them for you and see if you really want them first.
Mike "Bear" Shea
Old 08-23-2009, 12:50 PM   #9
terd ferguson
I appreciate it.
Old 08-23-2009, 08:35 PM   #10
gostranger
gostranger's Avatar
hey thanks i am looking forward to hearing back
Old 08-23-2009, 09:38 PM   #11
joe231
joe231's Avatar
pics of the grill please?
CHEVY ONLY
Old 08-23-2009, 10:40 PM   #12
49m
49m's Avatar
jst let me know shipping asap
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 08-23-2009, 10:53 PM   #13
Bears63
Bears63's Avatar
gostranger - PM sent w/ pics, pricing and shipping.
49m - PM sent w/ pics, pricing, and shipping.
Mike "Bear" Shea
Old 08-23-2009, 10:57 PM   #14
Bears63
Bears63's Avatar
Here are pics of the grille. I don't have it off the truck yet. It will be next weekend before I can get back out to get it off and get better pics.
Mike "Bear" Shea
Old 08-23-2009, 11:22 PM   #15
Bears63
Bears63's Avatar
terd: Here's a link to my PhotoBucket album of the doors. There's a bunch of pics. If you are still interested in 'em let me know, but I am a little doubtful that they would be worth the shipping cost. Check out the doors here!
Mike "Bear" Shea
Old 08-24-2009, 12:07 AM   #16
Bears63
Bears63's Avatar
Wiring harnesses - $5 each + shipping - in order:
1) Engine Harness - V8 w/ guages - This is a Classic Parts harness.
2) Light, Alternator Harness - This is the original harness. This is for the headlights, alternator, voltage regulator, horn relay, and horn.
3) Closer look at #2.
4) Tail Light Harness - This is a Classic Parts harness. It is the one that plugs into the tail light housing. One of the boots has some cuts.
5) Pics of cuts on boot from #4.
6) Park Light Harness - This is an original. It's the harness that runs through the hood to the parking lights.
Mike "Bear" Shea
Old 08-24-2009, 12:40 AM   #17
Bears63
Bears63's Avatar
Pics of the interior door handles and window cranks:
Cowl panel - $40 + shipping
Fender extension panels - $25 each + shipping
Mike "Bear" Shea
Old 08-24-2009, 12:40 AM   #18
Bears63
Bears63's Avatar
Left wiper arm - $5 + shipping
Radiator Holddown - $10 + shipping
Radiator Support Panels - $20 each + shipping
Park Light Bezels
Mike "Bear" Shea
Old 08-24-2009, 07:08 AM   #19
283 Man
283 Man's Avatar
if Joe231 doesnt take 63 grill .Im interested in it shipping to 72712..
283 the mighty small block
283 Man is offline   Reply With Quote
Old 08-27-2009, 12:02 AM   #20
Bears63
Bears63's Avatar
283 Man: The grille is still up for grabs. I can do $30 shipping. I'll get it off the truck this weekend.
Mike "Bear" Shea
Old 08-27-2009, 11:32 PM   #21
49m
49m's Avatar
money has been sent
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 08-28-2009, 01:07 AM   #22
slepysal
slepysal's Avatar
i am looking for the rear tail light assembly right and left mainly the housing and trim ket me know how much to Ca. 95131 tthanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-28-2009, 04:34 AM   #23
283 Man
283 Man's Avatar
Smile Re: Parting out '63 C10 Longbed Fleetside
Ill take the grill ,just p.m. me your address and total amount plus shipping and i can mail you a money order thanks Morton
Old 08-28-2009, 07:36 AM   #24
Bears63
Bears63's Avatar
49m - Payment is being processed, thanks. I'll get that clutch bracket off the truck tomorrow so everything ships together.
slepysal - I have both housings yet, but the socket on one of them is buggered up. Only one lens is any good and the bezels are missing in action, I think someone made off with them. I will get pics of the housings and the one lens today and send them to you after I get off work. The two housings and lens I can do $20 to your door. I will look again this weekend for the bezels.
283 man - PM on the way
Mike "Bear" Shea
Old 08-30-2009, 07:49 PM   #25
Bears63
Bears63's Avatar
I added more pics. Click the links to see them, I put them on PhotoBucket to keep the thread a little less cluttered.
Solid front bumper. I do also have the mounting brackets put don't have pics of them yet. The brackets are $15 for the set.
Grille Support. It's got issues such as rust, a few dings, and a couple of holes filled with Bondo. $25 + shipping for the whole thing or I will cut it up if anyone would like patch pieces off of it.
Fan Shroud Panels. These are the panels that the fan shroud bolts to and also seal the radiator area. $25 + shipping for the set.
SlepySal - I got pics of the tail light housings. Like I said before, I only have the one lens. I looked for the bezels but they are missing. Also, note that one socket on one of the housings is not very good.
Mike "Bear" Shea
