Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-23-2009, 01:59 PM   #1
nomad0231
To Cut, or not To Cut?
Hello all - I have a custom '69 C10 and need a radio system to finish it all up. I have yet to cut the dash and am considering it cause I just don't like the look of the radios that can fit our inserts. I would still get something that looked a little retro, but not as cheap as the USA ones and others out there. The truck is not original,kinda mixed between years, so what are your thoughts on cutting it to make a standard deck fit??
nomad0231 is offline   Reply With Quote
Old 08-23-2009, 05:12 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: To Cut, or not To Cut?
depends.. f you choose a deck that matches the rest of your interior and lighting scheme.. cut away.. go for it!
but i would use some of the metal cut off to make a "support" bracket for the bottom side of yoru reciever.. just to be anal...
sometimes due to the demands of current technology you have to make sacrifices.. and cutting a dashboard to me seems like a easy one to make..
at least you arent cutting apart the dashpad or glove box or center console....
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-27-2009, 01:32 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-05-2009, 03:23 PM   #4
big_al_71
big_al_71's Avatar
cut it!!!!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-06-2009, 12:00 AM   #5
AceX
>130dB Moderator
AceX's Avatar
You don't have to cut. Brother's Trucks has a unit in stock that will provide you with an decent base with alot of expandability.
http://www.brotherstrucks.com/prodin...number=CS06300
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-06-2009, 12:09 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You can also install an aftermarket headunit in the glovebox.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-06-2009, 12:31 AM   #7
AceX
>130dB Moderator
AceX's Avatar
We jsut did that in Dad's El Camino and I do not recommend it unless you buy an auxilary RF controller.
Living Life @ 130dB
RIP El Jay
Old 09-06-2009, 08:49 AM   #8
nomad0231
Well, I decided not to cut it. It looks so good untouched! So, I ordered the radio from Manes and should have it soon. Now I'm wondering how hard it's going to be splicing into the wiring harness!!!
Old 09-06-2009, 07:09 PM   #9
AceX
>130dB Moderator
AceX's Avatar
Should be easy enough. There's some diagrams posted here and in the main Electrical forum.
Living Life @ 130dB
RIP El Jay
