Coil Over ?
Looking for any info on what coil over spring rate to use in my 66 Fleet.This will be mainly a street trucks.
Ladder bars narrowed 9" 4.56-33x21.50x15 496 bbc(500-600hp) Turbo 400 @2800 stall Thanks Last edited by ProStreet Dream; 09-06-2009 at 05:14 PM. |
Re: Coil Over ?
We would need to know:
Rear weight Leverage ratio (where are the shocks located? how many inches from the front hole on the lower control arm) Coil length uncompressed Coil length at prefered ride height Total travel of coil over shock/spring With out ALL this info it's a major shot in the dark..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 09-06-2009 at 06:04 PM. |
Re: Coil Over ?
I would start with a 170lb spring if it's mounted rear of the axle vertically.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#4 | |
Re: Coil Over ?
Wow that's a lot of info that i do not have clue about.I just picked up the truck a few weeks ago.Someone else did all the hard work now i am trying to finish.It looks like they put in a piece of exhaust tubing to set the ride height.(the rear end was upside down in this picture)
Chris ![]() ![]() ![]() Last edited by ProStreet Dream; 09-06-2009 at 08:24 PM. |
Re: Coil Over ?
I would not take a guess with 170lb springs. You set up is much different than Airmale's.. He has a 4 link, you have a ladder bar. Looks like Airmale has a factory frame where yours is backhalfed. Batterey location can have a huge effect.. All the little things add up. If you want it to be perfect you need to do some homework. Otherwise you can keep guessing shipping parts too and from a parts vendor like Summit.
A 13" long 170lb spring isnt going to give you the same ride height as a 15" 170lb spring. There is a lot that goes in to selecting the right spring. As far as rear weight, it's going to be different than a factory set up. Your best bet is to put the bed on it, get everything done to it, put it on a scale, then buy your springs. To get compressed and uncompressed lengths, you need to take a shock/spring off. Expand it take the measurement from the bottom of the spring perce to the top. Compress it, take the same measurement. Then for the ride height, set it back in the truck, put jack stands upder the rear frame so it's at the height you want. Then measure the top/bottom of the spring perch again.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 09-06-2009 at 09:09 PM. |
Re: Coil Over ?
can't argue with that. but looking at what you have it's a safe starting point, you may wind up with 150lb. I run a stock frame, batt. in rear and 20gal cell at the tail. good luck.
Re: Coil Over ?
Thanks for the help.
Looks like i should just wait until the end of the build and take it to the scales to get the weight right the first time.That way i only have to set it up once.Your right my setup is different back half,bed is gutted(only has thin sheet metal floor)15 gallon cell and 2 batts. Chris ![]() ![]() Last edited by ProStreet Dream; 09-06-2009 at 11:03 PM. |
