Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-30-2009, 10:50 AM   #1
mark's68
trouble codes
I've got a 93 s10 that is giving the code # 43 electronic spark control. The book said the ESC retard singal has been on for to long or the system has failed a functional check. What can be done to fix this problem. I've been noticing that the engine sounds like the valves are rattling under part throttle- full throttle. Thanks for any help.
mark's68 is offline   Reply With Quote
Old 10-01-2009, 09:48 PM   #2
mark's68
Re: trouble codes
it was the knock sensor
Old 10-05-2009, 07:16 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: trouble codes
you DID torque it to 15 ft.lbs., right?
68C15 is offline   Reply With Quote
