Old 10-04-2009, 09:49 AM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Blazer 4wd to 2wd question???
I have a 1980 2wd drive blazer rolling chassis. I want to put this under a 1987 4x4 blazer to make it 2wd. This would probaly be easier than change all that suspension, right???
Tony Kee
Texas Square Bodies
Last edited by texassquarebodies; 10-04-2009 at 09:59 AM. Reason: Changed question
texassquarebodies is offline   Reply With Quote
Old 10-04-2009, 11:56 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Blazer 4wd to 2wd question???
Yep, but you will have to change some 2 or 4 body mounts but it's not hard. That's what I have been told.
tvblazer78 is offline   Reply With Quote
Old 10-05-2009, 09:03 AM   #3
tobiahr
tobiahr's Avatar
having swapped the front suspension on one and the cab on another i would say the cab was difficult because of size and weight but easier than the suspension swap.
tobiahr is offline   Reply With Quote
Old 10-05-2009, 05:17 PM   #4
texassquarebodies
Truck Nut
I have got a 2 post lift and square body parts coming out my ears!!! Just trying to figure out easiest route. Anybody else know about swapping body mounts? I even have a rolling lwb truck frame to put that body on while I am working on the chassis.
Tony Kee
Texas Square Bodies
Old 10-05-2009, 06:17 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
if you decided to swap the suspension parts this might help
http://67-72chevytrucks.com/vboard/s...d.php?t=168231
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-05-2009, 06:20 PM   #6
Jonboy
Slots go on anything!
I think you might be able to swap the bodies like you are suggesting. On the later model bodies, I am almost positive the bodies are the same. The earlier tubs had a few different mount configurations, but I think you are good.
