My step son has a jeep, straight 6 in it, he just called me said that it will not start!
Give you a quick run down on it. It has gas in the tank. Before this happen he said that when he made a quick stop the jeep would die. When he backs up fast and hits the brakes he said the engine revs up fast for a sec. He changed out the fuel filter, and the fuel pump thinking this was the problem. Did not help at all, this is a 85 jeep. It has a carburated engine. Then he told me he pulled the filter again, and there was a lot of pressure built up and when he broke the fitting loose it sprayed gas out. So with this said, I think the problem with it dieing out when he hit the brakes is the float needing to be adjusted. Man he drives this everyday, so it has not ben sitting at all, what do you guys think could be the problem? Sam
72 LWB chevy truck. Pasadena, Texas |
its all about the +6 inches
I agree, crack the carb opn and see whats up in it.
The fuel spraying on filter swap shows good fuel pressure. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! ![]() Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
TTT
