Old 11-25-2009, 10:22 PM   #1
509nat
509nat's Avatar
Future gasser '57 chevy
Looking for ideas or suggestions to raise stock front axle 2 or 3 inches for that gasser look.
Thanks,
509nat is offline   Reply With Quote
Old 11-25-2009, 10:36 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Future gasser '57 chevy
Man i love that body style!
Scott
93 crew cab build
Project 62
Old 11-26-2009, 12:12 AM   #3
72hotrodder
THE TOY STORE
72hotrodder's Avatar
lower the leaf spring mounts. or go cheap and buy some blocks
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know.
72hotrodder is offline   Reply With Quote
Old 11-26-2009, 01:31 AM   #4
drivea55
drivea55's Avatar
I am with you, cheapest way and easiest is to block the leafs... IMO
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 11-26-2009, 05:25 PM   #5
OrrieG
OrrieG's Avatar
Generally not a good idea to use blocks on the front axle, lots of side loading from the steering.
OrrieG is offline   Reply With Quote
Old 11-26-2009, 06:37 PM   #6
scotts62
One day...
scotts62's Avatar
Cant you do shackles too? Not too familiar with that setup but thought they have them...
Scott
93 crew cab build
Project 62
Old 11-26-2009, 08:55 PM   #7
drivea55
drivea55's Avatar
I think he is right man, either way shackles or blocks will mess with the steering linkage. I am very new to this but sounds and looks like it would affect steering.
what about adding leafs? my 3/4 ton sits high and has just as beefy leafs in the back as it does in the front.
either way sounds like a new pitman arm would be in order to correct steering issues.
current project;
Old 11-27-2009, 01:27 AM   #8
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Sorry, A square body guy chiming in on this one. You should be able to find some leaf packs that are the same width but are longer than your current ones. Then just bolt them in place. And, I agree that you would probably need to adjust your steering just like you would with any lift. But that is a way I have seen many vehicle types get some cheap, subtle lift.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 11-30-2009, 11:52 PM   #9
509nat
509nat's Avatar
Work begins in stripping down to the bare bones!
Life is GREAT!
Old 12-02-2009, 12:05 AM   #10
hardwaa
hardwaa's Avatar
Here is some pics inspiration.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 12-02-2009, 09:24 PM   #11
Knothead
Knothead's Avatar
You can buy a power steering conversion kit and just use the idler arm and steering arm. This shifts the connectin to the top of the King Pin. That will give you about 5". I also went to a later year steering box, Steve
Knothead is offline   Reply With Quote
Old 12-03-2009, 03:46 AM   #12
drivea55
drivea55's Avatar
that is just some cool **** to have the headers come through the inner fender wells...
oh!, and be high enough to see them...lol
current project;
Old 12-05-2009, 02:05 PM   #13
chevyrestoguy
chevyrestoguy's Avatar
I'm diggin' that black n' flamed GMC
chevyrestoguy is offline   Reply With Quote
Old 12-05-2009, 03:03 PM   #14
drivea55
drivea55's Avatar
yeah, me too! I think I found the inspirational photo that i needed.
current project;
Old 12-10-2009, 01:12 AM   #15
509nat
509nat's Avatar
Cleaned, wire brushed and painted frame.
Rebuilted front spindles with new kingpins and bushings.
Upgraded to front disc brakes with five bolt pattern.
Lots of work!
Old 12-10-2009, 01:29 AM   #16
509nat
509nat's Avatar
I decided to add 2" blocks to raise the front end for the time being and see how this pans out. Also added a later power steering box and steerimg kit.
Installed a Pontiac Trans Am 10 bolt posi with 342 gears with rear disc brakes and fabricated new spring pershes.
Project is moving forward!
Old 12-10-2009, 01:40 AM   #17
Twitchin R&C
looks sweet man. and if you still need an inch or two more just get some longer shackles and you'll be good
Twitchin R&C is offline   Reply With Quote
Old 12-10-2009, 04:42 AM   #18
lonelywanderer
i'm used to seeing cars but those gasser trucks look pretty cool...
lonelywanderer is offline   Reply With Quote
Old 12-10-2009, 01:11 PM   #19
OrrieG
OrrieG's Avatar
Nice work. I wish I had a lift..
Old 12-31-2009, 12:06 AM   #20
509nat
509nat's Avatar
Here are some pictures of Chevy 409 motor distained for future gasser '57.
Work in progress!
Old 12-31-2009, 01:00 AM   #21
Kim57
Kim57's Avatar
Love the engine. I've been toying with the idea of trying to find one for my truck.
Kim
Kim57 is offline   Reply With Quote
Old 12-31-2009, 01:15 AM   #22
OrrieG
OrrieG's Avatar
Didn't know Edlebrock made heads for 348-409. I've always liked them too. Were they ever available from the factory in pickups in 58-59?? I know the 348 was an option in the cars but we called the truck engines when I was a kid. Big trucks only?? I suspect the HP was a bit more than the 425 advertised too.
Old 12-31-2009, 03:03 AM   #23
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Looks good. I wanna get a '57 someday.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 12-31-2009, 03:35 PM   #24
dwcsr
Hollister Road Co.
dwcsr's Avatar
283 was the biggest you could get in a 2 wheel drive 58-9. 235 was the biggest in a 4x4.
dwcsr is offline   Reply With Quote
Old 12-31-2009, 05:06 PM   #25
CAL 58 GMC
CAL 58 GMC's Avatar
Work in progress!
Sweet motor!
CAL 58 GMC is offline   Reply With Quote
