Old 11-27-2009, 04:22 PM   #1
BigChevy80
BigChevy80's Avatar
California Quadrajet?
Question for the Quadrajet gurus on here. I was running the numbers from the Quadrajet on my '72 GMC and came up with something interesting. 7040511. As far as I can decipher, this carb was made in 1970 and is a California emissions carb. What is the difference between it and a regular Quadrajet? Can I rebuild it back to regular specs or should I look for a different core?
And no, I'm not interested in putting a Holley or Edelbrock carb on it!
-Tony
Money is no object... once it's in your wife's hands.
1972 GMC Sierra
1977 Ford LTD II
2000 Pontiac Grand Prix (wife's ride)
BigChevy80 is offline   Reply With Quote
Old 11-27-2009, 04:46 PM   #2
Wrenchbender Ret
Re: California Quadrajet?
Its probably just a little lean. When you build it check the size of the main metering jets. They usually run about .072-.073. There are variations in the metering rods but I'm not familiar with the sizes. You may want to decrease the tension on the sec. air valve springs.
Wrenchbender Ret is offline   Reply With Quote
Old 11-27-2009, 04:47 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
You can talk to Sean at SMI
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
