Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-28-2009, 02:07 AM   #1
aggieguy713
aggieguy713's Avatar
Installing a Radio Head Unit?
How hard is this task in a 70 chevrolet? Ill be starting from the ground up. So my question is, for the average person (or high school kid ), how hard is this task? Any info greatly appericated.
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 11-28-2009, 11:02 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Installing a Radio Head Unit?
moving this to the audio forum.
You may want to list exactly what kind/type of system you are installing, and if you have the brand and/or model, then the guys there could prrobably give you a step by step post.
Old 11-28-2009, 11:38 PM   #3
aggieguy713
Thanks. The head u it is a sony xplod. Basically I just need to know where to hook the 12v cnstnt, 12v ign.
Old 11-29-2009, 04:52 AM   #4
AceX
>130dB Moderator
AceX's Avatar
I don't know the colors of the wires but you will need to find the acc., ign., and ground. The ground can be put anywhere using a ring terminal and some clean bare metal.
The wires from the deck should be labeled.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 11-29-2009, 02:29 PM   #5
aggieguy713
the 12v power is yellow, i have a way its grounded, and the accessory wire is red, my question is, does this wire (the accessory) need to be run?
Old 11-29-2009, 07:38 PM   #6
AceX
>130dB Moderator
AceX's Avatar
Yes, that's your constant 12v source.
Living Life @ 130dB
RIP El Jay
Old 11-29-2009, 07:49 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
aggieguy... check out my build thread as I did a similar install earlier this year in my '69. IIRC, I posted the wire color and the terminals I used to hook everything up on my Kenwood headunit. Good luck with the install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-29-2009, 08:11 PM   #8
aggieguy713
Thanks guys. Got the Unit in and the speakers wired up, works like a charm. 72blck, thanks for that info, i followed what you did step by step. helped a ton.
Old 11-29-2009, 08:16 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Glad to hear you got everything installed. Now turn it up, I can't here it.
-Nate
