Old 11-28-2009, 11:44 AM   #1
mikey531
mikey531's Avatar
Unidentified 200 4R
I have found 2 2004R transmissions but nothing matches up to tell me what model or year they are! Can anyone help?
mikey531 is offline   Reply With Quote
Old 11-28-2009, 07:36 PM   #2
mikey531
mikey531's Avatar
Re: Unidentified 200R4
Anyone? I have been looking at every 2004R site I can find and nothing matches. What am I doing wrong?
Old 11-28-2009, 08:19 PM   #3
2tons of fun
200r4, sounds identified to me.
does it have a bop or chevy bell?
whats the out put spline?
2tons of fun is offline   Reply With Quote
Old 11-28-2009, 08:27 PM   #4
mikey531
mikey531's Avatar
It has the universal bell housing. I wanted to find out what year and car it came out of. That is where I am having the problem.
Thanks.
Old 11-28-2009, 09:57 PM   #5
ebfabman
KJ '86 to '90
ebfabman is offline   Reply With Quote
Old 11-28-2009, 10:19 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Old 11-28-2009, 10:50 PM   #7
CSGAS
optomistic ah-so
CSGAS's Avatar
I'm guessing what you are really trying to find out is if it came from one of the models with the higher strength ratings, Like the Monte SS, Buick GNX, Olds 442.
Buick units are identified by the BQ or BRF transmission codes. Monte Carlos used the CZF code. The Hurst Olds/4-4-2 units had a KZF or an OZ code.
Any other code (KJF, TKM) was a standard build.
Hemmings also lists the following decoding info:
1st digit: month of production (A through M, skipping the letter "I")
2nd-3rd: production day of the month
4th: shift transmission was produced (1st-3rd shift)
5th: assembly plant (T: Three Rivers, MI; J: Windsor, Canada; W: Warren, MI)
6th-7th: decade and year
8th-9th: or 8th-10th: transmission ID code
10th-13th: or 11th-14th: transmission serial number
While that info is oversimplified and the second tranny (yellow tag) seems to have some conflicting info (like NO production shift, which could result from OT weekend, or labor trouble) it still seems to be from a 1982 Oldsmobile. The first one is so far off I think it would be a good idea to look at the pan and make sure it's really a 200-4R
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 11-28-2009, 11:53 PM   #8
ebfabman
look here
http://web.archive.org/web/200701281.../thm2004r.html
Old 12-03-2009, 12:35 AM   #9
425HP409
425hp409
425HP409's Avatar
Re: Unidentified 200 4R
The month and year of the trans case is in a small circle on the left side of the case above the shift lever. Like 3 86
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
