Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-05-2009, 04:19 PM   #1
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Finally -- shop heat
A while ago, I had this stupid idea I could heat the new shop with an air-tight wood stove. 36' x 36' x 13' ceilings.
So, when I finally smartened up, here's what I went with.
Natural gas-fired radiant tube heater - 60,000 BTUs
20 feet long with a 90 degree elbow at the half-way point.
Whisper quiet.
The next challenge is to get vapour barrier, drywall (gyprock) and insulation up there so I'm not heating the great outdoors through the roof vents. It's a long way up there.
www.67HEAVEN.com
2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme)
1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme)
1967 Belair 2-door-post (project)
1967 Corvette 427/435 coupe (now 502/502 red road warrior)
67HEAVEN is offline   Reply With Quote
Old 12-05-2009, 04:21 PM   #2
CG
BlahBlahBlah
Re: Finally -- shop heat
Dang, thats a nice set up. Do you plan on insulating? That would help a ton Im sure.
Old 12-05-2009, 04:26 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
Yeah, sheet rocking that's not going to be fun. I dig the heater.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-05-2009, 08:50 PM   #4
Indian113
Indian113's Avatar
A friend of mine has that same set up in his shop,he says the more stuff you have in your shop the better it works.Also once you set your heat temp leave it alone as it takes awhile to heat every thing back up! Nice shop- rent a sheet rock lift,don't count on friends like I did.
Indian113 is offline   Reply With Quote
Old 12-05-2009, 10:16 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sweet heater set up we have those at work....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-06-2009, 12:13 AM   #6
Rollie396
someday it will be done!
Rollie396's Avatar
I just put one in my garage as well,just needed a 30000 btu unit for my little 20x22 but it's been great so far!My garage is insulated and boarded,but I'm taping,mudding,sanding and painting right now.....yea it sucks .
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-06-2009, 11:21 AM   #7
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
I bought one, but it only lifts to 11 feet. That will work for the walls and the lower perimeter ceilings. We came up with a plan for the high ceiling.
We're going to place the drywall lift on an open car trailer to get the extra height required.
www.67HEAVEN.com
Old 12-06-2009, 11:35 AM   #8
463
463's Avatar
if you can, rent a electric scissor lift for high work. time and labor and a safety to think about.
Trueman
463 is offline   Reply With Quote
Old 12-06-2009, 01:02 PM   #9
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Nice
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 12-06-2009, 01:57 PM   #10
Leinie
You should be able to put an extension on the sheetrock lift lift. nothing more than a piece of pipe with a reducer on one end.
Nice heater- glad to see it's not Modine ( we've had nothing but problems with the 4 Modine units we have at work)
Leinie is offline   Reply With Quote
Old 12-06-2009, 05:23 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That is quite the setup... nice!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-07-2009, 06:09 PM   #12
rambler
MOVE OVER
rambler's Avatar
I like it, what does one of those run for?
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 12-07-2009, 06:21 PM   #13
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Approximately $CA3,000.00 installed.
www.67HEAVEN.com
