Old 01-03-2010, 04:20 PM   #1
Brewski*
Brewski*'s Avatar
Unhappy ?71 3/4 ton 4x4 front end not working corretly making loud popping noise and slipping
My 71 3/4 ton 4x4 front end is not working correctly. I was up cutting wood the other day (ice and snow) and backed up a small hill. Heard a loud pop (passanger side) now it kinda does this slipping> pop> engaging slipping> pop> engaging. It will drive for a while then do it again when I stop and start. Seems to pull to one side a little and steer funny when not working. I already changed out the Warn locker on the passanger side it did not help. Checked the locker on the drivers side it seems fine. Any clues? HELP?
Brewski* is offline   Reply With Quote
Old 01-03-2010, 04:25 PM   #2
jgdually83
jgdually83's Avatar
Re: ?71 3/4 ton 4x4 front end not working corretly making loud popping noise and slip
sound to me like internal problems i would pull to cover and look for any broken gears. do you check the axle joint?
83 K30 3+3 Dually
83 K20
jgdually83 is offline   Reply With Quote
Old 01-03-2010, 04:37 PM   #3
Brewski*
Brewski*'s Avatar
Joints appear to be good and intact. They are only a year old. Everything else is pretty new also. I will probably pull the cover when the snow lets up and see what I can see. If anyone else has had this problem let me know. Seems to go fine until one wheel starts slipping.
Old 01-03-2010, 05:04 PM   #4
LONGHAIR
If the axle joints are good, it can really only be the spider gears in the differential or the lock-out hubs.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-03-2010, 05:13 PM   #5
mstrav1973
mstrav1973's Avatar
possibly chipped a tooth on a spider gear or axle shaft? did you try turning the driveline with the hubs un-locked to see if there is a pop coming from inside the differential? you said you swapped your locking hub and nothing changed?
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 01-03-2010, 05:36 PM   #6
rwolf9653
more ideas than money
rwolf9653's Avatar
X2 on what everyone else has already said,
but I would also like to throw in there that you should check you drivshaft for binding in the u-joints. It could be another problem area if pulling the diff cover yeilds no obvious problems.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 01-03-2010, 09:55 PM   #7
OrrieG
OrrieG's Avatar
If you have a 203 transfer case it might be the stretched chain slipping under load. It sounds like the noise is coming from the passenger side.
OrrieG is offline   Reply With Quote
Old 01-04-2010, 09:49 AM   #8
Brewski*
Brewski*'s Avatar
NP 205. The noise sounds like front passanger but I could be wrong. It only does it once or twice then it works OK until I stop. Then it will do it again. Does this help any?
Old 01-04-2010, 10:23 AM   #9
bigrigpardo
not to intrude but i have a similar problem when i put my 69 in 4wd i get a pop pop pop pop from the transfer case if u put ur hand on the transfer case shifter you can feel it.
any ideas
bigrigpardo is offline   Reply With Quote
