Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-19-2010, 12:24 AM   #1
gmcdude
gmcdude's Avatar
Dash Speaker
Are the dash speaker hard to change on a 72 GMC.
gmcdude is offline   Reply With Quote
Old 01-22-2010, 09:24 PM   #2
gmcdude
gmcdude's Avatar
Re: Dash Speaker
I guess no body has changed them.
Old 01-23-2010, 02:21 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Re: Dash Speaker
Sorry, I've never worked on one personally. I would imagine that it isn't very hard to do. Should be pretty straight forward. 4 screws, 2 wires and a little time.
I'm not sure waht the factory size or power rating is, but it can't be very big in either case. Look at LMC truck or Clasic Industries for a replacement speaker. Both should have a couple options available.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-25-2010, 06:42 PM   #4
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: Dash Speaker
I replaced mine with a "custom" plate that houses (2) 3.5" speakers. It isn't hard to change out, but may test your patience. You will need to take out the OG radio if still in to get the speaker out. At least I wasn't smart enough get around it. What I did was take out the speaker and used it as a template and traced it on to 1/4" MDF board. Used the 3.5" speaker as another template to cut out the speakers in the MDF board. Painted the MDF board rattle can black and reinstalled it.
72 cheyenne pdx is offline   Reply With Quote
Old 01-31-2010, 03:10 AM   #5
red71c10
The Red Menace
red71c10's Avatar
Re: Dash Speaker
Can you clarify what you are trying to do? Are you trying to get the factory speaker out of the dash? What are you planning on replacing it with?
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 02-10-2010, 10:57 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Dash Speaker
What're some options for putting a speaker there? or speaker(S)
John
1999 Toyota Tacoma 4x4
Old 02-11-2010, 03:25 AM   #7
red71c10
The Red Menace
red71c10's Avatar
Re: Dash Speaker
Instead of stock you can put a dual cone stereo speaker in the stock dash location. If you don't want dash speakers, you can go with kick panel speakers or even put in a headliner with built in speakers.
Old 02-11-2010, 04:46 PM   #8
72 cheyenne pdx
Re: Dash Speaker
As my post stated I have (2) 3.5" speakers. I believe LMC, brothers, and the like make replacement speakers.
Old 02-13-2010, 11:21 AM   #9
gmcdude
gmcdude's Avatar
Re: Dash Speaker
red71c10 I'm just putting in a modern speaker made for the dash, where the stock one was at.
Old 02-13-2010, 11:19 PM   #10
glider_6969
Re: Dash Speaker
I just installed 2 four inch 200 amp speakers in the factory spot under the dash, yes it will test your patience and put you in positions you never thought you would do :lol I removed the radio, the ash tray and mount and the heater controls to get to it. Name:  IMG_0119.jpg
glider_6969 is offline   Reply With Quote
Old 02-14-2010, 01:35 AM   #11
red71c10
The Red Menace
red71c10's Avatar
Re: Dash Speaker
OK. You might need to fab a bracket or come up with some creative mounting. I think when I did what you are doing in my old '68, I pretty much had the speaker sitting on top of the radio.
Old 02-19-2010, 12:09 AM   #12
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Dash Speaker
i made my plate out of sheetmetal and pop rivets, i have two 3.5's in the center speaker hole and one eachin the stock locations.
i have a total of 8 components in the cab..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-19-2010, 09:35 PM   #13
suttoncurt
suttoncurt's Avatar
Re: Dash Speaker
Originally Posted by glider_6969 View Post
I just installed 2 four inch 200 amp speakers in the factory spot under the dash, yes it will test your patience and put you in positions you never thought you would do :lol I removed the radio, the ash tray and mount and the heater controls to get to it. Attachment 546903
Wow - what kind of sound do you get outta thoes ? Thats pretty neat!
suttoncurt is offline   Reply With Quote
Old 03-24-2010, 12:19 PM   #14
glider_6969
Re: Dash Speaker
Well, I can feel the vibration in the glass,
Old 03-24-2010, 05:55 PM   #15
suttoncurt
suttoncurt's Avatar
Re: Dash Speaker
Any part nunbers or round about cost of that "upgrade"?
Old 03-28-2010, 09:00 PM   #16
glider_6969
Re: Dash Speaker
no real part numbers. The speaker are 4" and I was able to get the speaker sfor about $50. The audio place gave me a deal because I also bought 6x9 for behind the seats (which are rated for 150 watts each), truck has plenty of sound. I haven't tried to take it to the max, not sure I want to. What I recommend is shop around.
Old 03-29-2010, 01:40 AM   #17
dammitmitchell
the pollock
Re: Dash Speaker
mine had 3 3.4 kickers in the dash
and 4 6.5's in the rear, i made my own corner brackets out of sheetmeatal (easy =-))
and the speakers were bought on a kicker sale for 250 total for all 8..
the second part to this is adding an amp for the components (100 with wiring etc)
and then a sub with amp (probably a JL 8in which is amazing.....) for about 400 ish....
entire stereo will be done for about a grand... but will be great for my little cab
Army vet 02-08
