Old 02-04-2010, 09:36 AM   #1
BBGMC
BBGMC's Avatar
Unhappy Suspension Issues Need help
Ok so I have a 1968 GMC 2500 with a Big Block 402 it has the Original Front Suspension on it and I mean Original all the way down to the Shocks which I would say is a great bit overdue for changing, but surprisingly they don't leak nor show signs of ever leaking, besides the point I need to rebuild the suspension I just did an alignment and found out my Idler arm is really worn out along with my Tie Rod ends. I was figuring if I am gonna replace them i might as well rebuild the whole darn thing,now I also want to Drop it 4-5" in the front and maybe 4-6" in the rear without having to notch the frame. I was wondering if there is anyone that knows of a 3/4 ton kit available I want to keep it an actual 3/4 ton I also looked through cpp but there's no lowering kits for the 3/4 ton on there. any ideas??? also I like having a rake id like to offset it a little more than now which is barely noticeable what would be the best measurements for that also?
also I am looking for a complete front end rebuild kit that includes the center link both upper and lower ball joints both inner and outer tie rod ends with new adjusting sleeves a new idler arm and possibly a new pitman arm a arm bushings the whole 9 yards, go big or go home right,
Thanks a Bunch
BBGMC
BBGMC is offline   Reply With Quote
Old 02-05-2010, 09:36 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Suspension Issues Need help
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-05-2010, 10:03 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I'm doing my 70 C10 right now and have had great luck at my local parts store the parts will vary in price from one store to the other ..mostly with the pitman arm and if your going to do the link probably that too??..all say it will take a couple days to get them in but theres no shipping and from what I have found if something is wrong its an easy drive to town....besides on things like that I like to spend my $$ localy if I can...
as far as your drop be sure to check your rear axle clearance before you order anything...with out a notch you maybe looking to end up with a axle to frame issue 4" will probably be ok but 6" ????
ever consider putting bags in it they ride great are an easy install and weight isnt an issue
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-05-2010, 10:12 AM   #4
SCOTI
SCOTI's Avatar
Without upgrading to discs up front, you're limited to drop springs, stepped a-arms, or dropped a-arms for 'basic' lowering. If upgrading to discs, they make a 3/4 ton drop spindle.
Leaf or coil rear suspension?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2010, 10:26 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You may give wes at classic heartbeat a call he is pretty close to you and id bet he could get you all the parts ya need....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-05-2010, 10:34 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Look here at PerformanceOnLine, for c20 drop spindles:
http://www.performanceonline.com/sto...at=1075&page=1
Here's a quote from that page:
1971-87 CHEVY/GMC/C10/C20, 2.5" DROP SPINDLE SET #18992
These hot items lower the front of your vehicle without affecting ride quality or suspension geometry and bolt directly to the original ball joints.
Requires disc brake application.
Please specify year and model.
Use OEM ball joints.
Note: 1973-80 trucks use 1.25" wide rotors. 1981-87 C10 trucks had the option of 1.25" rotor or 1" rotor, please measure.
Details
Weight 55.00 lbs
Price: $ 228.99
Old 02-05-2010, 07:08 PM   #7
BBGMC
BBGMC's Avatar
I plan on Converting it over to Disc Brakes all the way around, the fronts first so buying Drop Spindles For Discs is what I have been looking for. I have a Leaf Rear axle its a Dana 60, I just figured if I am going to be in there I might as well give it a nice Rake for now. also I dont plan on dropping the rear anywhere near 6" that's too low for my blood I use my truck as a truck still but I want it to sit lower than it is now, right now the front is 15.5"(measured just in front of the tires) from the ground and the rear is 20.5"( measured just behind the tires) from the ground I figure a 4.5" drop in the front with a 3" drop in the back wil give it a nice rake and look like an old hot rod truck. Any suggestions on how that would look?
BBGMC
Old 02-05-2010, 07:21 PM   #8
my67c20
Just remember that if you upgrade to disks it will require the appropriate year ball joints. Don't ask me how i learned this, but if you need some 67 balljoints i happen to have a new set for a 3/4 ton.
my67c20 is offline   Reply With Quote
Old 02-05-2010, 10:13 PM   #9
SCOTI
SCOTI's Avatar
BBGMC
You could remove some of the leaves & swap in an AOL kit to regain the original capacity. Swap the drop spindles in & trim a bit off the stock springs (if you like the current ride).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
1968, 2500, chevy, gmc, suspension
