02-07-2010, 03:39 PM | #1 |
87 long bed
looks like im one of you guys now im 16 years old and stumbled upon this sweet 87 long bed 4x4 plans in the future incude a big lift and big block and some touching up only paid 3k for the darn thing heres just a few pics more to come
02-09-2010, 02:18 PM | #2 |
Re: 87 long bed
ok so im looking at about 6-8 inches of total lift what wheel tire combo would look the best
02-09-2010, 02:27 PM | #3 |
Re: 87 long bed
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by Liz; 02-09-2010 at 07:31 PM. Reason: wtb |
02-09-2010, 04:28 PM | #4 |
Registerd User
Re: 87 long bed
Nice looking truck dude. I like that color.
02-09-2010, 06:14 PM | #5 |
Re: 87 long bed
thanks, its getting painted idk what color yet though.
02-09-2010, 06:57 PM | #6 |
SWB 4x4 Collector
Re: 87 long bed
I'd like to welcome you to site, but you need to be a supporting member to post wtb ads. Also, why you going to paint it? You will be a lot of money ahead to run for awhile as is, and upgrade your hood and grille as you go. As far as tires with 6-8" lifts, somewhere between a 35"-38" tire would look pretty good. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-09-2010, 08:43 PM | #7 |
Re: 87 long bed
yea i dont know i just dont like the color and it needs some body work theres a few dents and im going to pull the cab and bed off and paint the frame and at that time some ladderbars and a big block
02-10-2010, 12:23 AM | #8 |
Re: 87 long bed
you can do a 6" susp and 3" body to clear 38's. 6" susp will clear 35" tires. I used to have 8" susp 3" body
02-10-2010, 11:07 AM | #9 |
Certified Hobbiest
Re: 87 long bed
i have cleared 38's fine with a 6" suspension / 3" body lifts
02-10-2010, 11:11 PM | #10 |
Chris
Re: 87 long bed
4 inch should clear 35's. we had 33's stock on an 86 and then lifted it 4 inches and 3's were way too small then.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
02-11-2010, 04:59 PM | #11 |
Re: 87 long bed
well heres my cluttered motor and interior
02-18-2010, 01:02 PM | #12 |
Sb 400 club
Re: 87 long bed
and a 4 speed too NICE! You should clear 35's with 4 inches of lift. I am at 4 now and clear 34 swampers with room to spare. Depending on what you going to use the truck for would dictate lift and tires. If it was me I would go 5-6 and re centered h1 headlocks and humvee tires. I like running trails tho.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
03-15-2010, 07:35 PM | #13 |
Re: 87 long bed
hey sorry for not keeping up on here. I have been hearing a real weird poping noise comming from the rearend of my truck and replaced the u joints. Well that wasnt the problem so i took the diff cover off and the center is gone. OOPs guess this means new 14 bolt rear end to replace the old.
03-16-2010, 05:37 PM | #14 |
Re: 87 long bed
ok so im thinking about switching the 14 bolt and dana 44 to half ton axle's. Im just wondering how much of a problem this would be? thanks
03-19-2010, 07:28 PM | #15 |
Re: 87 long bed
stick to the 3/4 ton man its deffinitly worth it they will last alot longer just rebuild that 14 bolt and it will be a nasty axle
78 k5 offroad project 350 sm465 60/14 np205 boatside, dovenose |
03-20-2010, 02:28 PM | #16 |
Re: 87 long bed
thanks for the advice im sticking to the 3/4 ton running gear and also i was cleaning the frame removing all the unneeded brackets stock exhaust...ect and i came across a deal that the rear brake line go into and come back out of but there is a bracket that piviots but then its bolted solid to the diff cover any help would be appreicated thanks?
03-22-2010, 07:57 PM | #17 |
Re: 87 long bed
a pic would be nice to see what your talkin bout
03-23-2010, 05:21 PM | #18 |
Re: 87 long bed
well come to find out its the abs system i found out from a friend i didnt know trucks this old had the abs.
04-09-2010, 11:27 AM | #19 |
Re: 87 long bed
They don't. What you're referring to is a proportioning valve that adjusts rear brake bias based on the load. When the bed is compressed from a heavy load, it provides more rear brake bias. I eliminated that from my truck when I put the lift in.
10-06-2011, 09:56 PM | #20 |
Re: 87 long bed
so whatever happen to this build?
