Old 02-09-2010, 05:11 PM   #1
Funeral
Funeral's Avatar
4x4 frame options for a 47 Chevy 1/2 ton.
I was curious about the frame options I had for a 4x4 frame swap, I have seen a 71 1/2 ton frame used. I have also seen a lot of S10 swaps obviously. I was looking for a full frame swap that would be 1/2 ass bolt on... any suggestions?
Funeral is offline   Reply With Quote
Old 02-09-2010, 08:03 PM   #2
winchster
winchster's Avatar
Re: 4x4 frame options for a 47 Chevy 1/2 ton.
73 up Blazer ( wheelbase is 10" short ) or short wheel based pickup ( wheelbase is 1" or 2" different )
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 02-10-2010, 08:54 PM   #3
Funeral
Funeral's Avatar
any recommendations as far as year?
I'll look into the blazers
Old 02-10-2010, 09:16 PM   #4
blackdiesel
blackdiesel's Avatar
i have not messed with an AD truck. but i do have my TF on a 77 swb 1/2 ton frame with 3/4 ton running gears. im pulling it off to put onto a 2wd frame, i like the street rod look better
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 02-10-2010, 10:09 PM   #5
winchster
winchster's Avatar
Blazers '73-'78 the frame kick is less, from what I understand
Pickups They are all virtually the same, the best bet is to choose based on availability, drive train options *gearing, t-case, transmission, etc*
I'm going to use a '78 K5 blazer.
Old 02-10-2010, 11:54 PM   #6
blackdiesel
What we did on gradpas truck was take a longwheelbase frame and we cut the step out of it when we shortened it, making it pretty much flat. Then we fliped the rear axle to on top of the springs to level it out. Then you have the correct wheel base. You do know the the AD is more narrow than the square body (73-87) and the wheels will stick out of the fenders.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 02-11-2010, 12:07 AM   #7
winchster
winchster's Avatar
Yea, but I think that is overstated. Here is mine as it currently sits. And as my signature states, '77 fullsize front saddle with regular 5 lug wheels. '69 rear axle with 12" wide 315's or something like that.
[IMG][/IMG]
edit: The wheels are turned slightly right in this picture, but it was the best one I could find that shows how far they stick out.
Old 02-11-2010, 12:15 AM   #8
blackdiesel
The 4x4 front axle is wider than a 2 wheel drive. You can use a dana 44 out of a jeep wagoneer their narrower than the chevy.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 02-11-2010, 12:21 AM   #9
winchster
winchster's Avatar
Not trying to be argumentative, however:
This is the information I find.
Wheelbase/Front Track/Rear Track
106.5, 65.75, 62.75--73-87 Chevy Blazer 4WD
131.5, 65.8, 62.7 -- 73-87 Chevy C-10, K-10 LWB
116.0, 59.5, NA,, -- 47-54 Chevy AD 1/2 ton
Old 02-11-2010, 12:30 AM   #10
blackdiesel
.05 is not much. I thought it was alittle more than that. What are you going to do with the 9.5" to short of wheel base?
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 02-11-2010, 12:38 AM   #11
winchster
winchster's Avatar
Shorten the bed. [IMG][/IMG]
That was the first one I saw. It had 67-72 rear fenders on it, but I like the way it looks. There is a guy on this board that has one, Gene, and I am going to drive up to where he lives and take a ton of pictures, notes, etc.
