Old 02-11-2010, 07:58 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
60-66 LSx swaps
My original plan was a boosted sbc, since my truck is already setup with a smallblock. Lately tho, a few threads on other forums have really turned me onto the ls motors.
I've only seen a few of these in our model, including some pics of super73's 63.
Who here has done the swap? Any opinions, any Links to detailed builds?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-11-2010, 09:44 PM   #2
TR65
TR65's Avatar
Re: 60-66 LSx swaps
Hey City,
Check out Tom Lamb's LS build here
http://67-72chevytrucks.com/vboard/s...d.php?t=346598
Here is another thread on the subject
http://67-72chevytrucks.com/vboard/s...d.php?t=364782
More good info here
http://67-72chevytrucks.com/vboard/s...d.php?t=371020
There are many more threads on the board for these swaps. The LS motors are awesome.
Here is my swap in progress:
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-11-2010, 10:59 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 60-66 LSx swaps
that looks sick!
Old 02-11-2010, 11:40 PM   #4
TR65
TR65's Avatar
Re: 60-66 LSx swaps
City,
Here is the ultimate LS swap thread!!
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
TR
1965 C10 SWB Fleet
Two owner
Old 02-12-2010, 11:19 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 60-66 LSx swaps
I have done the swap, the engine is a 5.3 but all stock. Just waiting on funds for exhaust.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-12-2010, 12:06 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 60-66 LSx swaps
clyde, what did you choose to use for motor mounts (3 bolt to 4 bolt adapter?), how about the fuel pump etc? I saw some threads in which you mentioned your 5.3 swap.
Old 02-12-2010, 12:27 PM   #7
nomrlz
nomrlz's Avatar
Re: 60-66 LSx swaps
Originally Posted by TR65 View Post
Hey City,
the only thing my son was upset about goin to an LS was loosing the big pancake thingy on top . told him i could fab sumptin up and now i can show him how it would look, thanks for the pic
nomrlz is offline   Reply With Quote
Old 02-12-2010, 12:46 PM   #8
66shortwide
Re: 60-66 LSx swaps
I'm working on one as well, but dont think much of the info I have is relevent. My motor is set back about 8" and I'm using an aftermarket crossmember and custom motor mounts. I used a 5.3 for now, with a ls6 intake, and looks like i"ll be using headers from a G8 GT.
Trent
12 Cadillac CTS-V
07 Sierra HD 4x4 Duramax
66 C10 Short Wide
63 Chevy II(nova)
66shortwide is offline   Reply With Quote
Old 02-12-2010, 04:39 PM   #9
Clyde65
Clyde65's Avatar
Re: 60-66 LSx swaps
I used the perches from POL ( Performance on Line), if I were to do it again, probably would use the ECE mount, just because of better Exhaust clearance. The trans mount you can get just about anywhere, the simpler the better on trans mount.
http://www.performanceonline.com/sto...cat=455&page=1
http://www.classicperform.com/Store/...uck/CP9427.htm
The fuel pump I got from Turn Key, they had the pre and post filter, pump, oil change tattle tale sensor and the oil pressure adapter, they are not cheap and when I do another, I will go elsewhere just cuz of the high cost and less than stellar service.
http://www.turnkeyenginesupply.com/e...at=1&key=parts
I wish I had a camera to take pictures. If you are doing this on a 63-65 chevy truck, you will need to redo your emergency brake lines. I am doing this now so inspection can be done, I went with the 66-72 cable design.
I also went with Sanderson shortie headers, CSLS1 model, ceramic coated and all, I like them.
http://www.sandersonheaders.com/prod...roducts_id=191
I would be happy to tell you anything I have learned, Thealien has a very nice write up here ( see above response), just about any question a guy could think of is answered in there.
Oh by the way, I used Wait4Me performance for the PCM and harness rework. Make sure you tell them what you need, If you do away with anything like AC, oil change tattle tale sensor, anything like that. They were the cheapest and it worked, you might choose otherwise.
http://www.wait4meperformance.com/
Clyde65
Clyde65
Rebuild of Clyde
support our troops!
Old 02-12-2010, 05:36 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 60-66 LSx swaps
Thanks Clyde. Mines a 66, I was considering NOT dealing with the e-brake, seeing as its an auto and I don't have to pass any inspections.
As for the mounts, your CPP link confused me, it went to a trans xmember? I see they have a kit with an engine crossmember, and mounts. Is that the one you were referring to?
Im running a fuel cell right now, so I think the inline pump with the 'vette filter/regulator might be a better/cheaper bet for me.
Old 02-12-2010, 05:44 PM   #11
70 Suburban
Rods
Re: 60-66 LSx swaps
Clyde where is your build thread
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 02-12-2010, 05:53 PM   #12
Clyde65
Clyde65's Avatar
Re: 60-66 LSx swaps
This is what I have for the motor mounts...
The CPP is the trans mount I have, sorry.
The 66 should be OK with the stock cable, on 63-65, they have a crossmember that uses a pivot type mechanism to apply the E-brakes, I am doing the full perimiter cable like the 66-72.
I too have the fuel cell, I used -6 russel fittings and hose for the fuel, Look at Thealien's post on the ls, maybe that will show you where to get the filters and the pump for a reasonable amount, I saw $515.00 on the TurnKey website. Yuk!
Clyde65
Rebuild of Clyde
support our troops!
Old 02-12-2010, 09:26 PM   #13
TR65
TR65's Avatar
Re: 60-66 LSx swaps
City,
You can use the original equipment LS mounts with our trucks if you do a little fabrication. The OE mounts are way more sophisticated in keeping engine vibrations out of the truck than the 1950's vintage mounts most people use. Another plus is that they won't interfere with anything, headers, AC compressor etc. Tom Lamb did it one way, I did it another. Here is the thread for the way I did it.
You can re-construct the original type e-brake system on the new cross member if you want. Here is a thread on that.
http://67-72chevytrucks.com/vboard/s...d.php?t=381313
TR
1965 C10 SWB Fleet
Two owner
Old 02-12-2010, 10:38 PM   #14
70 Suburban
Rods
Re: 60-66 LSx swaps
i used the adapter plates with mine and the stock 66 engine mounts
Old 02-12-2010, 11:08 PM   #15
Chevy-Art
Chevy-Art's Avatar
Re: 60-66 LSx swaps
Thanks for the info.
1990 Chevrolet RCSB●LS1/4L60E
Scrimpin Ain't Easy
Chevy-Art is offline   Reply With Quote
Old 02-13-2010, 01:07 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 60-66 LSx swaps
tr65, how hard were those mount plates to fab up?
Old 02-13-2010, 01:26 AM   #17
TR65
TR65's Avatar
Re: 60-66 LSx swaps
City,
The plates were very easy, just some bar stock, and angle iron. The hard part was locating the engine correctly. I positioned it about 5/8" higher than the original 283 and one inch forward, tilted back 4 degrees per normal. Once I finally got it positioned I tack welded the plates to the cross member with scrap angle. Then I could unbolt the mounts, pull the engine out and then correctly position and weld the final angle mounts that give the 3 bolt holes to mount to the frame, then knock off the temporary angles.
The engine is very easy to get in and out, and I have done it 4 or 5 times. Just hang it over the cross member and drop in the 6 bolts. You can easily reach the nuts on the inside of the cross member.
The mounts are oil filled hydraulic, very nice.
TR
1965 C10 SWB Fleet
Two owner
Old 02-17-2010, 12:57 PM   #18
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 60-66 LSx swaps
small update; found out one of my coworkers can get pullouts from some service vans and trucks for the cable company. ALOT of 6.0's and 5.3s floating around. Hopefully I'll hear in a week or so.
Old 02-17-2010, 09:33 PM   #19
TR65
TR65's Avatar
Re: 60-66 LSx swaps
Hey City,
If you get a pull out be sure to get as much stuff as you can to save money. If it is 03 04 or later get the fly by wire pedal. Curise control switch, OBDII port, fuse block for the engine, battery cables, AC lines, PS lines ...
I was even able to use the exhaust system and CATs back to behind the cab without modification.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
